Question about Refrigerators
I have a Kenmore refrigerator Model #106.74952401. First the freezer stopped making ice & was not cold enough. I wasn't sure what to do so I set temp for freezer to lowest & got frost off of walls. It is now working, but fridge is not cooling now. I can't find my manual. I think some of the parts need to be cleaned.
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
eagle338
  • 4889 Answers
SOURCE: freezer no frost
This is probably due to the failure of defrost timer or the heating coil..Try this
1)The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
2)If this doesnt work then Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
Posted on Oct 15, 2007
sdmc73
  • 121 Answers
SOURCE: warm fridge
check the fan in the frezer and check the defrost
Posted on Nov 29, 2008
gaeb7
  • 25 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ice is building up on back wall of a frost free refrigerator
Your defrost system must be on the blink. The defrost system is used to keep slabs of ice from forming and disrupting flow of air to that fresh food compartment. In the old days grandma would just unplug the unit every 2 weeks and place a chair in front of the the ice box, holding the door open for an afternoon to kill the frost buildup. Then came the modern frost free icebox. Every 8 hours the timer would kill the compressor and kick in a heater to melt that old frost. A bi-metal thermostat was installed in line with the heater to shut it down at 50 degreesF, then the ice box would just keep quite and set a spell (21 mins) then like magic the ice box would roar back to life, get cold, and chill out. That is until you opened the ice box door and violated grannys 3 second rule and caused the compressor to come roaring on and scare the cat half to death. Nowadays instead of timers(we don't need no stinking $2 timers) we built in computer boards with fancy sensors to monitor capacitance changes in the evaporator coils and issue orders from main computer board to defrost board to commence defrost cycle all the time monitoring for any changes in our daily habits, taking in consideration of how many times we peek into the ice box and look at grandmas strawberry shortcake. Keeping up with each and every ice cube we consume and checking the temperature and quality of our water and ice in the door. OH my! So what could go wrong? Well barring hurricanes, tornatoes, thunderstorms, earthquakes, and other natural disasters, all ice boxs still need a heater and a thermostat. I would start there. Of course if you had have specified a particular model number and brand so that a date age and a few components could have been looked at then I could have posibly given a more specific answer.
MORE
Posted on Mar 06, 2009
My Kenmore bottom freezer refrigerator model 59679243010 ice maker is mot working.
Check your temperatures, that typically happens when the freezer is not cold enough, Clean your condenser, that may be the cheapest fix.
Jan 19, 2016 | Kenmore Refrigerators
My Kenmore ice maker isn't working
check to make sure the freezer isn't set too cold, it will freeze the line. if it is, it can take a few days to free up. also, check to make sure the wire that stops the ice from overfilling is still in its slot.
Aug 13, 2014 | Kenmore Refrigerators
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Not cold enough
You have to balance the freezer and the refrigerator. The freezer runs both and if you have one set too low then the other suffers or if you have one set to high the other suffers. Make sure that nothing is blocking the air flow from the freezer to the refrigerator and make sure the coils in the freezer are not frozen with ice.
Aug 10, 2012 | Kenmore Side by Side Refrigerator
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
REFRIGERATOR OR FREEZER IS NOT COLD OR WILL NOT FREEZE
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
