Weber Genesis Silver C Grill
Problem for Weber Genesis Silver C Grill
Low and Slow heating to temperature on grill
By bigpines on Apr 29, 2008
cleaned tubes
changed tanks
adjusted regulator, no noticeable change in temperature
grill won't heat higher than 400, last year it would go to 550 in a short time
any suggestions??
Same Problem
Jun 18, 2008
-   My Weber will not heat up over 250 to 300 degrees-   larry730
May 12, 2008
-   My grill lights fine...but the flame is very low....could this be the same problem as reported....Weber Genesis Silver C Grill-   merdon
Best Solution
posted on Jun 03, 2008
Very Helpful)
ifixed
Rank: Apprentice
Rating: 100%, 1 votes
That was the problem, it happened once before and I corrected it without knowing. Found this site and your solution refreshed my memory that I had done this before and that is what must corrected the problem! Thanks!!
Was this helpful?
Yes
No
Solution #2
posted on Apr 30, 2008
Very Helpful)
Fireplacegir
Rank: Wiz
Rating: 94%, 65 votes
Here are some tips:
Check: The excess flow safety device, which is part of the barbeque to cylinder connection, may have activated.
Fix: To reset the excess flow safety device turn all burners control knobs and the cylinder valve OFF. Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. Turn cylinder valve on slowly. Then use your like you normally do.
Now the line is purged.
Fireplace-Girl
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jul 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
low flame will not heat up sometimes flame goes out
Popular Solutions for Weber Genesis Silver C Grill
Questions and Unsolved Problems for Weber Genesis Silver C Grill
Do you recommend Weber Genesis Silver C Grill?
Answer
Answer
my weber grill won't get hot--only goes to "test"
Answer
Weber gas grill not heating up past 350. Tank is filled. I can smell gas but tank not leaking
Answer
How do you reset the safety valve on a gas grill.
Describe your Grills and Smokers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Grill and Smoker Experts
Top Range & Oven Repairmen
in , MD
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Best Grills and Smokers
Recommended by Owners
See more>>
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
