FixYa.com
Tags:
JVC AV-48WP30 48 in. Rear Projection Television
Had the ICs burn out (by 2 users)
posted by kadyo8040 on Apr 29, 2008
Where would I be able to order parts for my TV? Thanks!
Comment by kadyo8040, posted on Apr 29, 2008
I had the ICs burnout I guess on my TV; would you be able to tell me where I could order parts for it? I'm in the US Air Force serving overseas. Please advise.
Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by srivera2, posted on May 25, 2008
my picture is doubling up and looks like a ball in the center and the linesare coming off of it??? any help? I here a lot about convergence??? ic's?
Solution #1
posted on May 11, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
You can get them at this distributor.
http://www.tritronicsinc.com/
But you didn't say which ICs you need.
If the convergence IC have failed they are usually other things to check. Write an exact discription of the problem.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
Screen went black
I was watching TV, then the... Answer This...
JVC Big Screen: Screen Bowed...
The screen is bowed top and... Answer This...
HORIZONTAL LINES ON TOP OF THE...
shows greenish horizontal lines... Answer This...
problem with your tv
I am having the same problem... Answer This...
JVC AV-48WP30 / convergence
I changed the ic's and the ohms... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
