Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Kitchenaid dishwasher leaking from door
Replaced gasket around door,replaced flange on bottom of door,caulked around dispenser(detergent)
  • 3 Answers
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Posted on Jul 12, 2009
    Genius:
  • 1,073 Answers
Remove the outer door panel close door and see where the water is comong from look at the round vent in the door area
Posted on Apr 30, 2008
  • volkag Sep 18, 2010
    Didn't look to close around the round vent, but did put a new tube seal, and the plastic strip at the bottom of the door and today a new soap dispenser as it looked like some soap suds and maybe leaked some, but it looked like water was coming down under the latch?? That seems impossible to get water their if the door seal works and it seems to be in the **** of the tube all up the sides across the top?
I have had water leaking from underneath my dishwasher and have found that on filling, water overflows top of the water inlet unit
My Miele 828 dishwasher started to leak at the front left corner. The leak became worse. I tipped the machine on its side and removed the rubber moulding connecting the base of the drum to the pump. I cleaned it out and refitted it finding two small coins inside. The leak persisted. I took off the top of the machine by unscrewing the two screws on either side and pushing the lid backwards. I switched the machine on and, with a torch could see that the detergent dispenser had detached from the delivery pipe under it. Using advice elsewhere on Fixya I undid the three bolts around the door and the three screws around the detergent dispenser; one is deeply recessed and easily missed. Than I unclipped the drain pipe behind the little door at the bottom left hand corner at the front. The front then hinges out from the left with hinges at the right side making the leaking connection easily accessible. Make sure you get the rubber flange well up the plastic tube as there is no flange on the tube to secure it. A possible design fault but the unit has functioned for ten years before the connection failed.
Sep 24, 2013 | Dishwashers
My black LG 24 builtin dishwasher has suddenly started leaking about 1/3 cup of water around the bottom vent on the door (LH side). How do I make adjustments to the door to stop this? I have already...
Check the door seal. To do this, make sure the door and the rubber gasket is complete dry. Apply a liberal amount of liquid detergent around the rubber gasket. Then close the door. Open the door and look for the liquid detergent to transfer onto the door. If there is a gap, then you will need to replace the door seal.
Jun 17, 2011 | LG Dishwashers
Leaking from bottom of door when in use
Take a flash light and check for cracks around the bottom close to the door...if none are found then...Depending on your brand there should be a black gasket around the inside of the dishwasher. Right where the door meets the unit. It should just pull right out. Turn it around and put it back in. Don't stretch it, but make sure the ends get to the bottom. If that doesn't help, The inner door (the part that has the soap dispenser) needs replaced. Hope this helps...
Nov 28, 2009 | Dishwashers
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
The insultation on the bottom of the door is wet. My repairman said water is getting behind the soap dispenser and the rubber gasket around the dispenser is hard. The dishwasher is only 4 years old. Is...
Yes it is possible, and depends on your water hardness. An easy was to check is to use a silicone caulking product and caulk around the dispenser. Let it cure fully before using the diswasher. Check for leaks.
Oct 05, 2009 | Bosch Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
I have a Kitchenaid KUDS25SHBL1 dishwasher that is leaking from the bottom of the door. I replaced the main gasket around the body that the door seals against, and it is still leaking.
Have you removed the outer door to check if the leak is coming from inside the door . also check the bottom door seal ? also check the around the soap dispenser as I have had to silicone around them to keep them from leaking before..let me know if this helps at all.
May 11, 2008 | Dishwashers
Removing the detergent dispenser
I have the same problem--mine is about 10 years old. To disassemble, looks like you will need to disassemble the complete door--screws around the inside edge of the door. At that price for a replacement dispenser, I will either try to fix or replace the blue arm, or replace the dishwasher. I don't believe its worth putting that kind of money in an old dishwasher.
Lew
Dec 10, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
1,379 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
