Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
No color from VHS on DVD/VHS player
I have a Panasonic NV-VP33 going to a Hauppauge WinTV HVR-1600 on a Vista 64-bit machine. DVDs display fine in the WinTV application, but all VHS tapes have no color.
any ideas?
-Wendy Sue
  • Anonymous May 16, 2008
    I have WINTV on Vista Home Premium 32 and no color when connected cable via a spliter or even otherwise
    Scholar:
  • 119 Answers
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Posted on Apr 30, 2008
No sound in Hauppauge WinTV radio under Windows 7 64 bit
Driver issue? I would go to the manufacturers website to check for compatible software...
Mar 20, 2017 | Hauppauge Televison & Video
Cannot play certain dvd discs the make is panasonic model num nv vp33
Panasonic NV-VP33 is a DVD/VCR combo unit. These are good, but limited in DVD media playback formats. It depends on the types of DVDs you are trying to play, and their region codes (if they apply).
This model will NOT play:
DVD-ROM / DVD audio / DVD+R (unfinalised) / DVD-RW / Blu-Ray (obviously).
This model WILL play:
DVD-R (finalised) / DVD-RAM (no finalising required) shop-bought DVD movies / CD-R (for JPEG/MP3/DivX) / DVD-R DL (finalised) / DVD+RW (titled or with a top menu to make them compatible with other players, but again, finalising not required).
You didn't specify which DVDs do not play in your unit.
I would be very concerned if your player didn't read ANY DVDs at all. I assume the image below is what the model looks like. I have never had any problems with mine.
Mar 11, 2011 | Televison & Video
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Jan 06, 2010 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV-HVR-1600 running windows XP on ATT uverse I can not get the TV Tuner card to pick up any channals I have tried the bundled SW and a thrid party software results were the same. I...
Most likely, all stations in your area have switched to Digital Transmission, and your card can no longer find any. If that is the case, then you need a new card (they are not convertable) sorry.
Aug 19, 2009 | HP Hauppauge WinTV-HVR-1600 NSTC/ATSC Tv...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Open Questions:
See all Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / Questions
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
1,050 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
