Question about Optoma EP732H EZPRO DIGITAL PROJECTOR Multimedia Projector
Optoma EP 732H Blue/purple tinge
Our computer lab uses a Optoma EP732H display. It is working but the images are dark and have a blue/purple color. I am using a dell latitude D505, and I have a smartboard attached. I've tried adjusting the color, temp, etc. It is on data setting, rgb. The conector pins are ok, The projector and the laptop are set to 600-800 high color. Read the manual but no luck for my problem. The bulb only has 200 hours on it.
The website is no help. I have also tried to reset but it won't let me change it to yes.
Thanks,
jmm521
  • glossic Mar 06, 2009
    I have loss of color with a purple/grayish tinge to the picture. I am runinng the projector connected to a DVD player. I have switched cables and don't believe that is the problem.
I have the exact same problem with my EP732H, and in the case of my machine it is not the cable that's at fault.  It is also not the color wheel's fault.  I believe the green data is not getting processed internally by the projector, so I'm only getting red and blue which makes purple.  This happens with all three inputs - the VGA, S-Video, and Composite.  I have my machine apart now but have not successfully fixed it.  Wish I could get hold of a schematic.
Posted on May 31, 2008
  • 563 Answers
Hi jmm521
Try using a different VGA cable as connection - WILL solve your problem !
Thanks for using Fixya !
Posted on Apr 30, 2008
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
My pictures have a purple tint to them
You're either using old/expired film, or taking photos during dusk. Color film is balanced for daylight photography. Using it under conditions other than that will result in varying color casts on the resulting images.
Fluorescent lighting: Greenish
Indoor bulbs: Reddish/orange
Outdoor at night/dusk: Blueish/purpla
Ourdoor at dawn: Pink/blue
Or, you may have just gotten bad print work done. Try a different lab.
Jun 12, 2011 | Canon EOS-AE-1 35mm SLR Camera
When printing dark blue or purple, it came out as dark or light cyan. Please advice.
Don't know what type of printer you have since you did not supply that info. But it sounds like the magenta or red ink/toner is not working on your machine. Since purple is made from using blue and red. Since you are only getting a cyan or blue color, the printer is not outputing the red. Check the red toner/ink cartridge to see if it is empty. Hope this helps.
Oct 08, 2010 | Samsung Office Equipment & Supplies
I,ve got a red spot in the screen i replaced the bulp but stil have the problem
it is most likely a burned polarizing filter. There is a polarizing filter on the blue light channel and another on the red channel. When black, or other dark colours are displayed, the red polarizing filter is supposed to block ALL of the red light being projecter. If the filter is burned, some light slips through and creates a red tinge on the projected image. If the red tinge only appears on dark images, but is absent when the images is completely white, a damaged filter is likely the problem.
Seems its hard to buy them. Best bet is probably buying a broken projector from ebay and stealing the filters out of it.
Oct 04, 2010 | Toshiba TLP 670 Multimedia Projector
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Display is very dark and can barely be viewed. Brightness controls don't do anything. Any suggestions? It is a Dell latitude 505.
Sounds like the back light has gone.
You may be lucky and you just have a loose connection, its worth taking the front off the screen surround and re-seating all conectors.
If it is the backlight, you can get a replacement quite cheap (£10)
I found this site
http://www.keyboard4laptop.com/ccfl-backlight-lamp-dell-latitude-d500-d505-p-4580.html?currency=GBP&language=en
Jul 11, 2010 | Dell Latitude D505 Notebook
How do you reset the latitude d505 to factory settings
How to reset the latitude d505 to factory settings:
If you have Windows XP,
Step 1: Backup everything that is important to you.
Step 2: Boot your computer using the Windows installable CD.
Step 3: Format your harddisk or repartition it.
Step 4: Install Windows XP using the installable CD.
Don't try this if you are not sure of what you are doing. It won't damage your laptop, but you might require a long time to get your laptop working again.
Jun 29, 2010 | Dell Latitude D505 Notebook
Optoma EP719 projector broken circular glass disk
The piece that's cracked is called a color wheel. I spoke with the parts department at optoma and they want $300 for a new color wheel for my ep 732h projector. I'm not sure if it's the same part but you can contact optoma on their website and they'll get back to you with a price quote for that part.
Jan 16, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
909 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
