Question about Linksys 5-Port Ethernet Switch (SD205-UK)
Both computers not able to connect to the internet
I'm not great with computers but here goes...I can one computer to connect to the internet but not the other, and if I switch it around, the other computer can get on but not mine. So I know both are able to, but I just can't get them both to connect at the same time.
  • 54 Answers
First see weather you have given a correct and diffrent ip address for both and the computer name should not be same and the check with the dns it shound be correct if you dont have any ask your service provider
if this all does not work check with the network cable it should be crimped striaght when connecting to a computer from switch and it should be crimped cross when you connect a modem to switch
and if you are not using a broadband via ethernet then you have to use a proxy
Posted on Apr 29, 2008
Need to connect reurbished dell GX520 to existing internet
first connect the "cat 5" cable to the dell's network card, the card has a square-ish hole with a little "cutout" in the top (for the cable's connector tab) the other end of the "cat 5" cable goes into the back of the router (you do have an existing router?) into one of the un-used square-ish holes (same cutout for the tab).
Then turn on the computer, see if the computer will "connect" to the router (that means it sees the router in computer-ish software).
IF that works then connect the router to the Modem (supplied by the "Internet Provider"... Then turn on the modem....
IF all goes well, your computer will now be able to connect to the existing internet.
Now for problems...
IF it seems to be connected correctly using the proper cat 5 cable, and it still will not work... turn off everything, start with the internet modem, then the router, then the computer... COUNT to 30 (1, 2, 3, 4... 29, 30) turn on the internet modem... count to 90 (1,2,3,4...90) turn on the router... count to 30 (1,2,3,4...30) turn on the computer... wait for it to fully boot, look down at the lower right of the screen and see if it can connect now.
IF it still doesn't connect, you may have to try another network card in the computer, or get a wireless USB "thingy" to connect to a wireless router...
Hope this helps...
May 21, 2014 | Dell OptiPlex GX260 PC Desktop
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
I got a asus g53jw-a1 and when i connect my internet cable to it.it goes very slow and when i connect it to another laptop that isnt asus its goes normal and fast. i have 2 computers and the internet goes...
Do you have your wireless connection enabled as well as your LAN connection (wired) connected and enabled at the same time? It may be as simple as turning the your wireless card off when your are connected with a wired connection. I would try that first and see if it that could be the issue. Shut the wireless card off and see if your results are different with just the ethernet cable connected.
Cheers!
J the Guru
Oct 16, 2017 | ASUS G53Jw-A1 PC Notebook
I have a Dell WindowsXP Home Edition Version 2002 Has my computer got Earthnet card please? We wish to go on broadband connection
you must be having motherboard disk with you. Insert it & install the network drivers in it. If you are not having disk, you can download the drivers from internet.
Jun 24, 2010 | Dell Ethernet Card Network Adapter
Computer not connecting to internet but modem still works
Power off the network router and internet appliance ( DSL or Cable modem)...
Wait a few minutes, and power them back on... Then power up the laptop after about 3-5 minutes.
Also, Get a good internet security suite. http://www.kaspersky.com is one I have had great success with my clients.
Another great place to check for Internet help: http://www.broadbandreports.com
Best wishes... :)
Jul 07, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Internet connection not detected
Try desconecting the router for a few minutes. Then turn off your pc and power on again your router and pc.
Feb 26, 2008 | Linksys Wireless-G WRT54GS Router...
Links Router Unable to Connect to Internet
if you go through the links router manual. it should show you how to reset the router.
Try resetting the router, it always works for me when my internet goes.
This is normal with wireless
Nov 10, 2007 | Computers & Internet
Linksys 5-Port Ethernet Switch (SD205-UK) Logo
137 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
