Question about Konica Minolta magicolor 2430 DL Laser Printer
Printing avery labels
I'm printing avery labels, and the colors is all blotched as if it fell off. If I print a regular paper, it's fine but the labels look awful
  • 167 Answers
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Posted on Aug 06, 2008
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper!
If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam!
Hope you found it useful, for futher questions i'm here :)
Dec 07, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
Print avery label from hp photosmart
could very well be try an ordinary print see if you have the same problem
Nov 19, 2017 | Computers & Internet
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Lexmark won't print on Avery labels
The printer is expecting the label stock to be loaded into the manual feed tray, not the regular paper tray. If it does not sense anything in the manual feed tray it will not continue. If you are loading the stock in the tray, it may need to be pushed further into the try to trigger the sensor.
Jul 05, 2009 | HP LaserJet 4650 Color Printer
How do I print Avery 8987 labels?
use the wizard on Office: Word. use this template
I suggest testing it on regular paper and then over lay it on the sheet of labels.
Good luck-
Will
compressionconnector.com
Feb 26, 2009 | Avery DesignPro Deluxe CD-ROM...
Printing labels
Go to here
and try their method to see if it works.
Feb 07, 2008 | OKI B4100 Laser Printer
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Konica Minolta magicolor 2430 DL Laser Printer Logo
284 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
