Question about Achiever SCS-6 Strip-Cut Shredder
STAPLES MODEL#SPL-826XSHREDDER DOESN'T SHUT OFF WHEN IN AUTO MODE-- told to clean shutoff sensor-however cannot find. Bob MY EMAIL IS rdgcpa@verizon.net
Cleaned the sensors with warm water and Q Tips. Works fine now..
For Staples shredder model #SPL-826X.
Thanks!
Posted on Apr 30, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
I had to remove the inner cover and then lift out the shredder mechanism. Inside center on opposite sides of the paper slot were the LED and the sensor. Since they are both simply mounted in slots without screws or glue I removed them one at a time and cleaned them. Mine had a build-up of shredder oil. I used cotton swabs and isopropyl alcohol to clean the LED and sensor and now it works correctly.
Posted on Sep 25, 2016
I have a Staples SPL-TXC15A shredder that doesn't start when paper is inserted. The power light is on and it runs in reverse but won't start when paper is inserted.
You need to change the direction or travel switch. Auto will only work when the direction of travel is into the bin, but you probably know that. There is an interlock on it. Use a vacuum cleaner crevice tool and then the brush attachment on both sides of the head. If that doesn't work, my guess is that the forward reverse switch is faulty. You would need to strip it apart and check with a meter.
Jan 03, 2017 | Kitchen Appliances - Others
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
I have an ativa shredder model MD 1250. Became jammed on some staples. Reversed it and pulled it out but no the auto shutoff won't work Is it fixable? The shredder still runs.
Robert,
Double check that you do not still have any paper that may have become stuck in front of the sensor for the auto shutoff. If there is something in front of the sensor it will keep running.
Jun 15, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
Auto setting will not work on Staples SPL-EXC8A
Cleaning of the paper sensors is essential. Blowing on the center of the paper insert area will clear the paper fibers near the sensor but not all. Since my shredder was way past warranty, I opted to remove the 7 screws on the back of shredder mechanism, gingerly remove the shredding mechanism from its seat and there I found, wedged in between one of the sensors, a solitary paper fiber. That ominous, evil paper fiber was wedged in so tight that even the jet engine blasts from a 747 aircraft would have not dislodged the paper fiber. Making use of a Qtip, I dislodged the paper fiber, cleaned out all remaining paper fibers in and around the inside of the housing, then reassembled the unit. It has worked satisfactorily since then.
Apr 24, 2012 | Aurora Electronics AS1018CD Shredder
When on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Jun 04, 2009 | Office Equipment & Supplies
Achiever SCS-6 Strip-Cut Shredder Logo
1,743 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
