Question about Gateway LCD26TV 26 in. Television
Lcd will not turn off
I have a gateway gtw-l26m103 lcd and recently have not been able to turn it off, and none of the buttons on the tv will work. I have my computer plugged in with a rgb and a hd tv box with component. when I turn the main power source on the power button light goes automatically to green when it usually is orange which means that the tv is turned off with the main power on. Now, when I push the power button(which is green) the screen will appear, and go to I am asuming the quickest input it recognizes that is plugged in because I now only have my rgb plugged in and it went straight to that input, and when I had both it went to the hd box.(which I had on last.) When I was watching the tv when I switched from hd to a regular station the screen would just blur like the tv couldn't switch back and forth. The volume button doesn't work and I can't get into the settings menu. Is this a processor problem or is there a way to reset the processor or just need a new one. By the way the picture quality is near perfect,(except when I switched from hd to regular digital cable.)
Same tv similar issue
the menu screen is garbled and the buttons don't work
have to input the numbers on my radioshack remote pushing a 1 then a 3 etc
must unplug cord to reset logic board I was told
great clear picture!! lisa
Posted on Oct 22, 2008
I own a Gateway GTW L26M103 LCD Television. When the set is turned off, the power button, which normally glows orange, now glows yellow, at which point the set cannot be reactivated. Unplugging the set...
Tv have power supply board issues,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 03, 2010 | Gateway LCD26TV 26 in. Television
The menu pops up on starting and continues to scroll. The front panel buttons on the TV do not do what they are supposed to do (i.e. Vol button changes input option, etc.)
i have the gtw-p42m102 and it did the scrolling thing and i had the image board dpwb11393-1g-l changed and it worked fine for 2 years.Now it made a pop like a firecracker and i am working in it now.
Aug 03, 2010 | Gateway GTW-P42M102 Television
I WOULD LIKE TO KNOW IF MY TV HAS DIGITAL TUNING? MODEL GTW L26 M103 THANKS RGBYRON338@GMAIL.COM
Sorry, according to the manual for the GATEWAY L26M103, it doesn't have a Digital Tuner.
Jun 08, 2009 | Gateway LCD26TV 26 in. Television
Screen changes between color as a demo function.no signal
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Sep 24, 2008 | Gateway LCD26TV 26 in. Television
GTW-P42M403
I actually bought the 5 year warranty when we purchased this new and it was still under warranty. Gateway is sending us a brand new TV. No need for me to try to fix this, but thanks to all involved.
May 29, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Blank Screen/Powers up, Power LED can be switched from ON (Green) to STANDBY (Red)
Billy K.
Mar 23, 2008 | Gateway LCD26TV 26 in. Television
Gateway LCD26TV 26 in. Television Logo
185 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
