My computer hard drive is bad - Computers & Internet
  • Kevin Flannagan
    Kevin Flannagan May 11, 2010
    What do you mean by the hard drive is bad?
  • john wasson
    john wasson May 11, 2010
    what do you mean bad? what is it doing? tell me in detail what is happening.
  • 3 Answers
Try formatting and installing a new operating system
Posted on Apr 29, 2008
The light is flashing on the front and it's making a clicking sound. I tried turning it off for a few days but it's still flashing and clicking and the computer doesn't see it.
A clicking noise coming from a hard drive often means the hard drive is bad. But it could just be the case is bad. I would remove the hard drive from the case and try to connect it to the computers USB port using a hard drive adapter. If it works, I would copy your music and data of ASAP. Then you can test the drive to see if it is bad or if the case is bad.
Jan 20, 2016 | G Tech nology g-drive combo 320gb usb...
Bad cluster and can not detect my desktop hard disk
Hard drives are formatted in "clusters". A "bad cluster" means that a portion of the disk is not working properly.
If your computer no longer recognizes the drive, then the drive is bad.
May 26, 2015 | Hard Computers & Internet
Hp hdd no show computer
Is this an external 1TB Hard Drive? Maybe it's to big for your computer. If it's an external drive try it on another computer and see if it works. There is also the possibility that the external 1TB drive is bad.
If it's not an external hard drive then try the steps below.
Click Start/My Computer and see if your hard drive is listed as a device. If not, turn the computer off, remove the battery, remove the cover that houses the hard drive on the bottom of the laptop then remove the hard drive from the bay. Wait 30 seconds and put the hard drive back into the bay and reboot. Now see if the hard drive is shown under My Computer. If not, the drive might be bad.
May 30, 2012 | Computers & Internet
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
Whenever logs in Windows defender scans the hard disks and gives the bad sector / RAM faults and 37 % unreadable hard disk and ask o purchase the s/w to remove those fault.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error also run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Mar 27, 2011 | Fujitsu (MHW2120BH) 120 GB SATA Hard Drive
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
Loud desktop computer hard drive
that is an indecator for bad HDD , keep backup from your data and expect the worst any time
Jan 20, 2010 | Dell Dimension 8200 PC Desktop
Notebook won't start
press the key F1 or F2 or F10 or DELETE when you try to restart your computer before 5 seconds that will open the BIOS page so go to boot order and change it instead of start with cd flopy hard drive put the hard drive first save it and restart the computer it have to work good un less there is a problem with your hard drive or windows software if that is the case restart the computer and press F8 before 5 seconds and you'll see black page with the next options last know good config and save mode click on last an then restart the computer if does not work try save mode of you can acces tue hard drive that means bad windows software if not bad hard drive
Jan 02, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
