Question about Kenmore Elite 45986 Front Load Washer
My Washer won't drain...? We have a Kenmore Elite HE3 about 5 years old at 2 minutes left of washing time it beeps and beeps and beeps. Say F 2 in the red letters so I stop it all and turn on the 11 minute spin and drain. Sometimes it takes 6-8 times before it will drain. Any thoughts? Julie soggy McKesson
  • ruggs Feb 16, 2009
    How do I get the bottom panel off?
  • kim1102 Feb 17, 2009
    My Kenmore ELite HE3t gets to the drain rinse and drain cycle and stops with an F02 troubleshooting code. According to the manual, this might indicate a clogged pump. How do I remove the bottom panel, it doesn't seem to want to pop off with a good tug.
My sister-in-law just had this issue. They took the bottom plate off the washer and found socks. So maybe there is something clogged inside that it hindering the water from draining out of your machiene too.
Posted on May 01, 2008
    Genius:
  • 1,028 Answers
Remove bottom panel and ckd pump for objectswatch for flood when you remove acess plug
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
Our Kenmore is washer is giving an F02 code and it is beeping it's a HE4 Elite and we've had it for 5 years.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite beeps all the time
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
MY kenmore elite has no power only beeps I see 2 wires to one board broken tryed to reinstall still no power. Can anyone help with this piece of shi_ has had 7 service calls
Jun 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis Washer 110.2709
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer cycle signal keeps going off an on turing cy
Jan 04, 2009 | Kenmore Washing Machines
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 - f2 blinking
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
275 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
