Question about Lands Phones
My phone does not ring and the answering machine does not pick up. I can make outgoing calls and if I call using my cell phone (where I know the phone is ringing) and pick up I am connected.
The phone company took responsibility for the problem
Posted on Apr 30, 2008
Vtech answering machine will not pick up properly
could be outgoing message is set to announce only without an anounce only message being recorded. see http://pdfstream.manualsonline.com/8/8c8ae66b-b461-40cb-b213-039e3c56ab64.pdf page 28
May 02, 2014 | Vtech ia5874 Cordless Phone
How do I change the outgoing message on a Panasonic KX-T7630 (landline phone) for when it is on night mode. I need to update our opening hours. Thanks
Sorry to read about your problem, I hope this helps you out.
if you are saying the answering machine wont answer..try calling and let it ring like 12 times, it will pick up
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Cell Phones
We can not receive incoming faxes. The phone ring once and then clicks off. We can use the phone. We can fax outgoing. How can we receive incoming faxes?
The problem may be in your phone line.
Try another phone in place of the fax machine and call in. You may find another phone does the same thing. It's possible there is a high-resistance short on the line. At low voltages during outgoing calls this won't affect anything (or it might occasionally cause some noise). But when your phone rings there is around 100 volts present. When the phone starts to ring, the short causes the phone company's equipment to think you answered and the ringing stops, but since the machine hasn't picked up the call then disconnects. If you have the same problem with a different phone, you'll need to contact your telephone company. They can test the line to determine where the trouble is. If it's in their outside wiring (moisture in the line or other defects), they would be responsible for fixing it. If the problem is in your inside wiring they will probably charge to come out, so they can provide some troubleshooting tips.
If another phone rings in properly, there is something wrong in the fax machine's line connection circuitry. Then you'll need to see about having the machine serviced, or consider replacing it.
Dec 07, 2010 | HP 1040 Plain Paper Inkjet Fax
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
# of rings before answering
Check to make sure you do not have distinctive ring option turned on.
Feb 05, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
I can not get my phone to pick up on the answering system when a caller is trying to leave a message
Try looking underneath the console of the answering machine. You must turn the answerer on on most machines and underneath there may be a switch to determine how many rings before it picks up as well.
Dec 26, 2007 | GE 28111 Cordless Phone
Lands Phones Logo
162 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
