Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Hoover savvy no suction on carpet setting
Hi I have a Hoover Savvy, that works fine on the bare floor setting but when
on the carpet setting the rollers spin, but there is no suction. the hoses are all
clear the unit has been stipped down and re-built, its like the suction motor
is not running. any Ideas
Thanks Andy
    President:
  • 1,673 Answers
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Posted on May 01, 2008
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
HOOVER VACUUM U8173-900
1) check the hose for blockage.
2) see the belt is slipin to due worn and replace .
3) check the bag/tank for full and need empty, and replace.
However go to the
http://hoover.com/support/video-instruction-guides/
and use the troubleshooting with common senses.
God bless you
Sep 06, 2012 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover savvy upright has no suction on carpet what's wrong?
9 times out of ten this is the response when you have a broken belt. The suction is the same but nothing gets picked up because there is no brush turning. Turn your machine off and see if you can turn the roller easily by hand. If you can you will need to change the vacuum belt.
If you are in Australia and need vacuum parts check out www.vacuumspot.com.au
May 12, 2012 | Hoover Vacuums
I have a hoover savvy that the rollers wont turn. I've taken it apart to make sure the brushes are not caught but nothing happens. I only used this vacuum once. It was a floor model when purchased. I just...
Hi there SmartAlec from NelsonVacuums.com.au here. I have to say that if it is not as simple as a belt - I assume that when you checked that the brushes weren't caught that you also checked that the belt was still on?. You shouldtake it back to the store you bought it from. Even a floor model should last longer than 1 vacuum!. the store should have replaced the belt before you took it home. Get them to check it for you.
Aug 26, 2009 | Hoover U8125-900 Savvy Bagged Upright...
Hoover savvy upright, replaced belt, but brushes will not turn
One of the common problems with the Savvy models is the upper handle switch. However if it is newer, you may also have an issue with the lower cable. To test it, turn on switch in carpet mode, and at the bottom rear, wiggle thr exposed black cable. if the roller starts and stops then it is bad and needs replacement. the cost of the part is about $10 but labor intensive to replace.
Feb 26, 2009 | Hoover Vacuums
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover Savvy self propulsion not working
The switch contacts are burned out and the switch must be replaced. This link sells the whole handle with switch but, check your serial number to be sure to get the right one. If you can use a Philips head screwdriver, you can do this easily.
http://buyitnow64.stores.yahoo.net/hovarepaswki2.html
Aug 21, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Suction problem
get rid of the carpet its shredding and falling apart.no sence in vacuuming old rotten carpet.or try using a vacuum without a brush roller and just suction
Jul 15, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Help
as the hose fits into the base (if i am correct) the power at the base should be fine, make sure the base is clean and free from blockage, you say the brush doesn't spin, has the belt broken, if so replace it, (very cheap) and only a couple of screws to undo, the roller not rotating will effect the power of suction dramatically, start from there and see how you go if i have helped please rate me
Sep 15, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
398 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
