Question about HP Pavilion dv6000z Notebook
Sound is not working on my hp laptop
Few days back I updated the software of my sound driver ,after that I am unable to hear any sound even when windows starts up . I can hear it thru my headphones not thru the internal speakers. it's a HP pavilion dv6131od.
I was unable to revert back the changes . So I restored the whole OS and still it's not working .
  • 2 more comments
  • Rohitmelkote May 02, 2008
    no I do not use headphones . but after the updates,i did try it with the headphones and it works but no such luck with the internal speaker .
    I checked the HP website and updated the Bios too
  • waakida Nov 08, 2008
    running PCLinux, same problem. Have sound, but very little. checked volume leval there all the way up, still nouthing. Volume is very low. havr tried with exrernal spkers same thing little volume. HELP! me.
  • REMY_KNIGHT Nov 30, 2008
    I have the same problem...when I put the headphones on it works but not the internal speakers....what do I do??
  • Prem Chugani May 11, 2010
    Do you use headphones often? When you updated your driver, were you using headphones then?
    Novelist:
  • 137 Answers
Did you RESTORE the OS or did you reformat and REINSTALL the OS? if you did a complete reformat and reinstall either 1) the software has changed Firmware settings and messed up the hardware or 2) The Reinstalling process has installed similarly unfunctional drivers or 3) there is an unrelated problem that is the real cause of the issue.
I'd try getting ahold of a whole set of drivers and trying each one. You might also want to look into BIOS updates for the HP, they might have fixed the issue already.
Posted on Apr 29, 2008
    Problem Solver:
  • 11 Answers
Hi Friends,
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Posted on Oct 08, 2010
Hi recently i had also the same problem with sound. i went hp office nd they are saying it is a problem with motherboard. they are solved the problem
Posted on Nov 09, 2008
2 Suggested Answers
SOURCE: sound is not working on my hp laptop
I had the same problem; my laptop's speakers suddenly stopped working but I could still use the headphones and sound was fine.
I played around a while and searched the net; and I got them to work:
Open Control Panel- Sound, Speech, Audio Devices-------->
1) Audio Tab
2) Under 'Sound Playback' hit Advanced
3) At the bottom where it has Speaker Setup change it to "Laptop Stereo Speakers" (mine was initially on "Desktop Stereo Speakers" for some odd reason)
Problem solved, Thank God (Alhamdulilah)!
Hope it works out for you :)
Posted on Apr 10, 2009
HI, iam having Toshiba Satellite 1905-S301 Laptop, and its sound is not working and even i have tried putting headphones into the jack but unable to hear d sound.. plz help if possible
hi. that problem have 3 thing
1- software draver damage
2- build sound card is disable in bios
3- sound card damage
first u need check in bios, look at yr sound card, if disable, change to enable it,
second check yr system properties looking for sound driver, if sound driver lost, u need get sound driver for your laptop and install it.
lastly, if sound device damage, i suggest u use usb sound device becouse cost to get it is very low
ok regards
contect me for future problems
Feb 19, 2011 | Computers & Internet
Unable to hear the sound after formatting
hi im josh in cebu phils. may i help you? friend the sound driver or IBM is built on the cd of the motherboard try to install it. then after installing im sure it still doesn't work because even the software is installed but it is not running. to make it run and you wl hear the sound. you need to update the driver manually. go to the my computer right clck device manager then clck the icon sound driver then update/install driver./if appears brwsing window.look for the sound folder in the drvce c then clck the run/setup wait until it completes.then reboot your pc.it will solve your problem just do it good luck hope i helped you.
Feb 27, 2009 | IBM (03R0329) Motherboard
Problem regarding sound of system
THIS MAYBE IN A FEW PLACES CHECK THE FOLLOWING FOLDERS IN THE CONTROL PANEL.
DEVICE MANAGER
NETWORKING AND SHARING
PROBLEMS AND REPORTS
SOUND FOLDER
OFF CHANCE IT CAN BE SECURITY AND WINDOWS ANTIVIRUS PROGRAM NOT ALLOWING YOU TO MAKE THAT CONNECTION
YOU MAY COM OVER A RED X
THIS MEANS NO CONNECTION
YOU MAY FIND RED,YELLOW EVEN ORANGE CHECK MARK THIS STATES THERE IS A CONFLICK WITH THE SOFTWARE OR HARDWARE OR BOTH, OUTDATED DRIVERS MAY CAUSE YOU PROBLEMS, OUT OF DATE UPGRADES ARE NOT COMPATIBLE WITH NEW DRIVERS OR OPERATIONAL SYSTEM SOFTWARE. THE LIST MAY GO ON FOR A LONG TIME, JUST TAKE YOU TIME AND GET NEW UPDATED FOR ALL YOUR HARDWARE AND SOFTWARE UPDATES TO DAY AND EVERYTHING WILL WORK OUT FINE YOU'LL
SEE.
ROD
Feb 25, 2009 | Compaq Presario 700 470024-192 Notebook
SOUND DRIVER
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51946-1&lc=en&dlc=en&cc=us&product=3540058&os=228&lang=en
Download this
sp36292.exe, (1/1 , 2.64M) and let your laptop find end update the corect drivers you need This is what the program do: Description: s.gif This package provides the HP Software Update for the supported notebook models and operating systems. HP Software Update is a proactive tool that automatically updates selective HP software and drivers. This tool comes pre-installed on the supported notebooks, but if it is accidently removed or lost, HP Software Update can be re-installed by using this package.
Good luck
Dec 07, 2008 | Compaq Computers & Internet
1) Audio Tab
Dec 04, 2008 | HP Pavilion dv6000z Notebook
Satellite A75-S206 : Audio Problems !
You need to download and reinstall sound card drivers for your laptop.
Here is sound driver download page from Toshiba.
Here is general drivers download page for your model
If the links above do not work, start from here, select your model, then chose download and select the appropriate driver.
Regards
Jun 06, 2008 | Toshiba Satellite A75-S229 Notebook
No sound
please give me details of your sound card, brand and model #
May 15, 2008 | Compaq Computers & Internet
No audio on Aver tv usb 2.0 analogue, M026.
If it worked before you updated the driver, so a system restore to the day before you downloaded the driver. That will set things back to the way they were before the driver update.
Mar 17, 2008 | Computers & Internet
Microphone not working, but speakers and sound is working.
First off, if they can hear you and you can't hear them, it's not your microphone. It is more likely related to your sound card, possibly a driver update could fix your issue. Go to Toshiba's support site here's the link for the portege model listed above: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modelLanding.jsp?ProductMenu_0=Portables&ProductMenu_1=Portege&model_find=S100-S1133&ProductMenu_2=1042298&moid=1042298&rpn=PPS10U&smoid=true&ct=MH&ListType=Model&x=27&y=7, and select drivers and look for the sound card drivers with the latest/most recent date, download them and update your driver to see if that fixes your issue.
Since you post that your sound works in other areas just not chat or Skype, you might also want to do a Windows update on their site and choose custom for your choice so you can review hardware and software updates to add to any critical/security updates found on your PC, and that may fix your issue also.
Good luck.
Oct 20, 2007 | Toshiba Portege S100-S1133 Notebook
HP Pavilion dv6000z Notebook Logo
526 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
