Dvd movie sound is slow
Running a new Acer xp media centre The DVD movie sound is slow on all disks. (DVD's) Have secondry IDE drive configured to hardware with DMA on. MP3's run normally.
  • 3 more comments
  • Robert Scott Apr 29, 2008
    No success on media player or media centre.
    Voices sound as as they have a drawled stutter.
    Same from cold start and no applications running
    Acer Aspire E500 1 gig ram
    Media centre 2002 with service Pack 2
    Pentium R4 3.4 gig
    Yes the slow stutter with speech using Microsoft or Cyberlink Power DVD is overcome by using VLC. This however is a roundabout solution...where does the current fault lie??
    Should I use a vista Pack on XP?? If I do use VLC as the player the Slow stutter with speech present in Microsoft Media Players and Cyberlinks Power DVD stops..but why?? Maybe it is codec but no problem on other similar machines.
    The problem is not with volume but disortion in speech. To reiterate, a dragging stutter. VLC does operate on the setting File, open disk dvd. File open disk dvd (menu) does not operate, I always get the picture but the sound again distorts).
  • Robert Scott Apr 30, 2008
    Have new Acer Aspire E500 1 gig ram
    Pentium R4 3.4 gig The DVD movie sound (Speech) is slow and stuttering on all disks. (DVD's) Have secondry IDE drive configured to hardware with DMA on.
    If I use VLC with no menus selected all is O.K. With the menu option the problem returns. This however is a roundabout solution...where does the current fault lie?? I would prefer to integrate the solution into Media Centre and not go outside it.
    President:
  • 2,712 Answers
Yes, as stated before, update your codec pack. You can also try K-LiteMega Codec pack (very popular) or even THIS.
Also, as Ekse said, use the AC3 Filter software. The link he provided is direct to the .exe file, and may not open always. HERE is the link to page you can download it from. ( I hope you don't mind, Ekse )
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 30, 2008
    If possible, try to update to Windows XP Media Center 2005.
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    solution.
    post them here.
    Cheers!
    IrishDruid
  • 13,433 Answers
Hello
First I would recommend you update your codecs.
The easyest way todo this is to get FFDSHOW which pretty much works with any type of movie
here is the FFDSHOW
http://www.free-codecs.com/download/FFDShow.htm
also for sound I recommend you get ac3filter
http://downloads.sourceforge.net/ac3filter/ac3filter_1_46.exe
More information about the ac3filter can be found here
http://ac3filter.net/projects/ac3filter
after you have installed these two, you should be able to use any movie player, without any problems, but I do recommend VLC.
I hope this solves the problem, if it doesnt let me know.
Thanks
'Ekse'
  • Ekse Apr 30, 2008
    honestly you just need the ffdshow and ac3 and everything will work. I dont like those huge mega codec packs.
    Ah well
  • 19,396 Answers
First of all try the Codec for XP, as suggested. Codecs are used to encoding / decoding audio when recording or reproducing dvd, a codec problem can give same effect. Also download and test a different burning software, to ensure it is not a software problem.
If codec is fine it is likely to be an hardware problem with your DVD rw drive , you will probably need to replace DVD burner, which is not an expensive part. If it was sound card you will have problem only on same pc.
First ensure 100% problem is not software.
  • Ginko
    Ginko Apr 30, 2008
    Check if the problem persists when you burn on different PC and play on your computer. If it does not, then is DVD recorder. If you have same problem with dvd burned on different computer , then the problem is between system/software and audio, or video adapter.
    Genius:
  • 1,142 Answers
Audio level too low.
In truth the audio level is too high on everything else. Movie soundtracks are extremely dynamic, ranging from near silence to intense explosions. In order to support an increased dynamic range and hit peaks (near the 2V RMS limit) without distortion, the average sound level must be lower. This is why the line volume from DVD players is lower than from almost all other sources.
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Apr 30, 2008
  • Maanita Chadha
    Why is the audio level from my DVD player so low?Many
    people complain that the audio level from DVD players is too low. In
    2V RMS limit) without distortion, the average sound volume must be
    lower. This is why the line level from DVD players is lower than from
    almost all other sources. So far, unlike on CDs and LDs, the level is
    much more consistent between discs. If the change in volume when
    switching between DVD and other audio sources is annoying, you may be
    able to adjust the output signal level on some players or the input
    signal level on some receivers, but other than that, there's not much
    you can do.
  • Maanita Chadha
    Why is the dialog hard to hear?Dialog
    (people speaking) is usually mixed into the center channel, with music,
    effects, and ambience mixed into other channels. If your audio system
    isn't hooked up correctly or doesn't work properly, the center channel
    might not be properly reproduced. If you have a system with only two
    speakers, make sure it is connected to the stereo outputs, not the
    multichannel outputs.
    In
    some cases the movie sound was not mixed well in the studio, making the
    dialog hard to hear. In this case there's not much you can do other
    than curse the sound engineer who thought sound effects were more
    important than understanding what people are saying.
    Try turning on dynamic range compression or check the disc to see if there is a separate 2-channel soundtrack mix.
  • Maanita Chadha
    Audio is only 12 bits.
    This
    myth was started by Widescreen Review magazine, which attempted to
    equate jitter in DVD players to a reduced audio resolution. DVD audio
    can be either 16, 20, or 24 bits. Jitter does not reduce the number of
    bits. There are many kinds of jitter. Jitter in the channel signal is
    accounted for in the readout circuitry. Jitter in the digital audio
    output is related to the audio circuitry and is independent of the DVD
    format. It's true that jitter at different stages can reduce audio
    quality, but comparing it to a 12-bit sample size is naive and
    inaccurate. Numerous reviews indicate that most DVD players sound as
    good or better than most CD transports.
    Genius:
  • 3,422 Answers
Did you make sure that the software your playing the discs with have all the sound settings to high..
Posted on Apr 29, 2008
  • Priya darshan Apr 29, 2008
    I would suggest you to use VLC player which you can download it from HERE for free.This is a real good software you can get a real high volume with it.
    Please don't forget to rate the solution
    Guru:
  • 1,342 Answers
Get the Vista Codec Packs:
32 bit version
64 bit version
  • 52 Answers
It sounds like your computer is having a problem syncing the audio with the visual. you can try to add more RAM to the computer, or you can make sure no other applications are running at the time when viewing a dvd. also try using windows media player to view instead of windows media center.
Using Windows XP. Want to copy vidoe from Media
Is the drive you are using a DVD writer or only a DVD reader? The drive that writes to RW disks is labeled DVD/RW or DVD Recordable.
These are the only drive types that will read and write a DVD/RW disc.
Jan 04, 2010 | Acer Aspire E500 PC Desktop
Acer 5102 with xp, It wont boot from cd.
Make the DVD your 1st option for booting. It's also your CD drive but is identified as the DVD RW. Once this is made your default (make sure you accept and save the change before exiting) with your installation disk in the drive, boot up and it will read off the disk and prepare your system for install. If your disk is bootable, this will work.
Dec 19, 2009 | Computers & Internet
Media player classic says "cant find dvd directory" when i put in a movie dvd?
try downloading VLC player
It is free, and it plays almost every video format
Nov 14, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Have 3680 came with win xp home and power dvd...did fresh install with xp disk no dvd player in start menu what next
There should be another disk which came with you note. It called Power DVD. Moreover you can download it from net install codecs and watch movie from windows media player
Sep 24, 2009 | Acer Aspire 3680 Laptop
I want to do a clean install on my acer to create 1 partition
What system are you running? xp? vista? Do you have the original systems disc?
Sep 14, 2009 | Acer Aspire 3610 Notebook
K9MM-V mB with DVD and CD drives .running XP pro .
make DVD drive the master, and Cd drive the slave. by set pin then have bios re search for them and try xp new hardware search with the new configuration
Jul 08, 2009 | MSI K9MM-V Motherboard
I have a compaq presario sr1517cl computer desktop and the dvd is very slow about coming on if at all
Try to Enable DMA in property of My Compter>hardware>device manager>Secondry IDE channel property...
Nov 29, 2008 | HP Compaq Presario SR5010 Desktop PC...
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Stuttering Sound
Hi again,
I'll let you know soon if there is another solution to fix it within your two players..
Apr 30, 2008 | Televison & Video
Acer T690 dvd not recognized
is this an ide drive? have you look for the jumper, single drive on one ide have no problem, but for two drives, one must be slave and the other a master. configuring your ide connections may fixed the problem.
May 20, 2007 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
