Question about Canon Pixma MP500 All-In-One InkJet Printer
Error 6A00 on MP500
HELP, turned off and on, unplugged, what can I try?
  • Anonymous May 09, 2008
    6a00
  • Anonymous May 14, 2008
    Canon MP500 Error 6A00
  • 22 Answers
I think the 6A00 is a mechanism jam code.
Regarding Error code 6A00. I have a Canon Pixma iP5000. I got that code. No easy answers on the net so I took it apart myself. The covers are all snap locked on. It was a bit painful but I got the side and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaners squeegie on the printhead. This mechanism seemed to be stuck at its full extention rather than being back at home base. Every time I turned it on and off I could see it tried to move but seemed to be stuck. I gave it a little assistance and that released it. I think it had become blocked up with drying ink and that had acted like a glue holding it out at full extension. The mechanism that drives the sliding squeegie relies on a spring
for it to return. The spring wasn't strong enough to over come the gluey ink and so the whole thing jammed up which is probably what the code means - jammed mechanism. If you are going to try it. Do not force any part of the covers. There are little arrows in the plastic indicating where the snap locks are, stick a flat head screw driver in to release. Trial and error will release the right ones first. You'll release one part only to find it hooked up at the next snap lock. Some are hidden under or on opening covers so keep looking. The base seems to be securly attached to the workings so don't try and get it off. Just top and sides. Ink is water based so a damp rag is all you need to clean.
/SPH
Posted on May 19, 2008
    Problem Solver:
  • 5 Answers
I fixed my printer what the problum is a paper was stuck if you open the right side of the printer where your memory card slot is.make shure that you have two screws in your hand one is when you open the printer and one is by the computer port, well you open that up and you will find a white thing that locks where your ink goes, there shuld be a small little peace of paper there
And also make to use gloves there culd be ink on that paper i had black ink allover my hands,
if you have any questions email me at wilkbrad@techie.com and if you need to aim please email me first thanks and i hope that helps alot o and make shure to put everything back on. see how it works it worked for me
Posted on Apr 12, 2009
Error code 6A00 when you turn printer on
AP position error causes the 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board assy (QM2-3078), Purge unit (QM2-2925).
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
I have a PIXMA MP500 printer. It is showing an error code 6A00. Can't find any reference to this in the User's Guide. What does it mean; what should I do?
Try first unplugging the printer power cord for ten minutes, ansd see if this correct the error, if not we will proceed troubleshooting.
Sep 09, 2008 | Office Equipment & Supplies
Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Pixma MP500 has a ERROR code 6A00 and the printer
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500
Hello my friend, check if print head carriage has stuck and move the carriage a few times. You can also blew some compressed air around to clear any foreign objects.Also you can try moving the cartridge back and forth a few times and when you do that restart your printer .If still doesn't work you should take it to a repair shop.Good luck:)
Feb 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon MP500 Error code 6A00... what is this about?
Error 6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00 mp500 canon
6A00 is a purge unit error, the station that cleans the printhead on the right hand side. Usually the wiper is jammed into the cleaning pads because of ink buildup. Water on a Q-tip can help clean that area or you may need a new purge assembly about $29.00
Oct 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
6A00
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Error 6a00 in my mp500 pixma
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
3,161 people viewed this question
old marine
old marine
Corne Viljoen
