Question about Kenmore 22422 Top Load Washer
Kenmore washer machine heavy duty 70 series
When warm or cold water comes on it makes a whistling sound. Could
this be a hose ?
    Genius:
  • 1,028 Answers
Most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Posted on May 01, 2008
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: i have an old Kenmore Heavy Duty 70 series washer.
Did you clean the mesh screen filter in the end of the hose where it connects to the valve. It can stop up with sediment.
Posted on Nov 05, 2009
I have a Kenmore Heavy Duty 70 series washer older model. It will not alow cold water to fill washer. Tried warm and hot water only fills the tank. Hot water will fill fine with no problem.
shut the house water valve off,take off the cold water line on the back of the washer and stick it in the tub of the washer,have someone hold the hose and turn on the cold water valve,if water comes out then you need to change out the water valve on the washer,if no water comes out then you have a problem with the house water valve.there are screens in the valves see if you canpop out the screen and clean it out and put it back into the valve,you can try that but sediment could have went through the screen and damaged the valve,if so change it out.next time send the model number and i can give you part numbers,let me know what you find
Sep 04, 2010 | Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
The screens are filled with minerals which cause the washer to fill very slowly, need to know how to get at the screens so I can clean them. Kenmore Heavy Duty 70 Series washer.
HI thanks for your question.remove the hot& cold hoses. inside the valve you will see screens. scrape with a small screwdriver. replace hoses & try. if it works, great if not replace water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Washing Machines
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
318 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
