put key in ignition turn to on position and wait for a couple of minutes for code reset to occur.could be battery you have put in is faulty if it has been sitting on shelf for a while
try putting the key in the ignition and turning it to on then holding the unlock button for 30 seconds and then remove the key and try the remote if still no good go to your dealer and get them to reinishalise the system
fuse 56 and 57 control central locking,the issue is caused by surges typically in the front door lock actuators, normally at a dealer they would replace fuse 56 and 57 with a 20a mini fuse and if still occuring repl the door lock(s) that dont work or typically both front, first replace fuse 56 and 57 with 20a fuses as were too small from factory and than operate ten to 15 times, if it doesnt work at first dont panic,let the car go to sleep which takes about 16 min and than try again this problem has nothing to do with the key fob or the lock unlock button inside,also the fuses are located behind the glove box just rere the access panel and they are found at lower left section
leave ign off with key out 3mins disconnet battery 5 mins reconnett and press lock/ unlock repeatedly until locks cycle through to re sync try this any probs come back to me
