Question about Apple M9034LL/A Keyboard
IMac Aluminum Keyboard not all keys working
I have an iMac with the aluminum wired keyboard. Suddenly, some of the keys have stopped working, including "l", "u", and "?". Since these are frequently used letters in the English language (among others), is there a way to fix this without buying a new keyboard. Many thanks for your help
  • 5 more comments
  • Anonymous Nov 22, 2008
    same problem. different keys. the , and the . does not work
  • Anonymous Dec 21, 2008
    My problem is with capital A. I'm unable to use the shift-a combination to make the upper case version. I have to use the CAPS lock key until I reboot. It comes back after a reboot.
  • parismca Feb 18, 2009
    my keyboard numbers on the right had side does not work
  • Anonymous Mar 20, 2009
    all of my letter (alphabet) keys don't work. mines wireless
  • hatti641 Apr 22, 2009
    I have the same problem, different letters, after spilling coffee on it.
  • Anonymous May 06, 2009
    Similar problem here but lucky it's 'only' the enter on the number pad that doesn't work anymore.
  • Eliise Lapointe
    Eliise Lapointe Jul 27, 2017
    I've got a similar problem today. u-i-o-p, j-k-l, m weren't working. The problem was a mouse key.
    To resolve Go to
    system preferences< accessibilityI realize that some of the keys were doing the mouse job. So then uncheck and everything should come back just fine!
  • 600 Answers
These keyboards do not service simply, sorry but at least any usb keyboard will work
Posted on Aug 24, 2009
2 Suggested Answers
VinayT
  • 1884 Answers
SOURCE: I'm having a similar problem with the wired aluminum keyboard
If you feel there may be some moisture in the keys then blow thekeyboard with your hair dryer with its heat turned off.
Posted on Aug 07, 2009
7ujm buttons stopped working
check to see if you spilled liquid on your keyboard. are the keys sticky that is a sure sign of juice of coffee spill
Jul 13, 2013 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
Remove macair keyboard?
since it is a unibody design (the whole computer's made of one piece of aluminum to please god knows who) you can't remove the keyboard in one piece. Rather, you must take out each key individually. This is done by putting a small flat object (butter knife, screwdriver, tooth of a PC fanboy) into the crevice between the aluminum and the key, and prying upwards very carefully (READ: very very carefully). if you were hoping to replace the keys with a new set, you then need to pry the small plastic ring under each key off the removed key, and attach that to the new key, and then gently (READ: very very gently) push that back into the open keyhole. since you did not explain why you want to remove the keyboard that's all i can say, but if you need any other help i'd be glad to.
May 29, 2013 | Computers & Internet
Cpu fan spin and stop
1) Computer unplugged from power, computer case open, Anti-Static Precautions FOLLOWED;
Use a flashlight, and inspect the Electrolytic Capacitors.
(Provided your motherboard doesn't use just Solid Polymer Capacitors)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.youtube.com/watch?v=YCSNWi3UHf4
http://www.hardwaresecrets.com/article/595
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw?P=1z0z7l5
Radial Aluminum Electrolytic Capacitor
Close examination reveals no bad 'caps', then test the Power Supply's 3 main voltages;
3.3 Volts
5 Volts
12 Volts
All are DC Voltage
Or use a KNOWN to be good, Compatible power supply for a temporary test unit.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Computers & Internet
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
My apple aluminum keyboard not working with Macbook Air
try to connect your keyboard to the mac air while mac book is connected to internet (by wifi) then update your programs (apple menu - update).
Dec 22, 2009 | Apple Computers & Internet
Aug 07, 2009 | Apple M9034LL/A Keyboard
Hi Bilbo,
Do you know if the keyboard has come into contact with any liquid? That can cause shorts in some of the connectors. Regardless of reason for failure, these keyboards, when they start failing, do not have repair options. Purchasing a new or used one will be the only option.
Keep in mind that these wired keyboards are also no longer made by Apple, but you can find them online at various sites. You can also use different Apple-friendly brands like Logitech if you'd prefer to stay with a wired keyboard.
Sep 30, 2017 | Apple M9034LL/A Keyboard
Ekse: Aluminum keyboard follow-up
Hey,
The problem is definitely on the computer - software side. as both of the keyboards work fine, its just a software issue. Can you get the original software back to your mac?
Sep 02, 2008 | Apple M9034LL/A Keyboard
Malfunctioning new aluminum keyboard x 2!
are you sure its a issue with the keyboard, I would suggest trying these two keyboards on another system to see if they really are at fault.
Thanks,
Ekse
Aug 28, 2008 | Apple M9034LL/A Keyboard
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
Apple M9034LL/A Keyboard Logo
4,015 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
