Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Staple function is grayed out - how do you turn it on.
  • 167 Answers
You do n ot need to enter the Service Tech code to ajust finishers. In fact that code should rarely be entered.
Is the option available while copying?
If it in the driver, select the greyed out option and let the driver inform you of the problem/setting.
Has the finisher been identified in the "instaled options" tab of the driver?
Normally, the driver or panel will indicate what the conflict is if any. If all these have been set correctly, contact whomever installed this finisher and have them do it properly.
Posted on May 27, 2008
    Champion:
  • 214 Answers
Do you have finisher / stapler installed machine, what model finisher you have ? finisher and stapler adjustment is done under service menu. chooce utility, details from laft and stop-0-0-stop-0-1.
there is a finisher option. where you can adjust staple function
Posted on May 11, 2008
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Canon Image Runner 4570 saying load staples when staples have been replaced
yes, there is in additional function then Common setting then finisher or staples you swicth to off
Mar 06, 2013 | Canon imageRUNNER 4570 Copier
Where is the fraction function on the BD-107i calculator
On the Staples Scientific Calculator BD-107i, I can't find the fraction function. I don't think there is one.
Mar 02, 2013 | Staples Office Equipment & Supplies
Trying to load the staples into a model #90010. They're fine except at the very front of the stapler, they wont go all the way down flush with the others and the chamber won't even close.
1. Make sure you have the correct staples for the machine, Swingline Hvy-Duty Staples for 90010 Stapler, 0.625-Inch Leg Length, 2500 per Box (90009)
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
They will replace the stapler if needed.
Apr 14, 2011 | Swingline ® LightTouch Heavy-Duty Stapler,...
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
Can't find staples for the Swingline powergun 1000. Suggestions?
use arrow #606 in the gray box. the back of the box lists compatible staple guns.
Aug 31, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Error E000532-8001 on iRC3170
532 means the staple head is not moving into posistion you might want to open the door and of the finisher and stick some folded up paper in the door interlock and see if the staple head is hitting something when it tries to move good luck
Jan 01, 2009 | Office Equipment & Supplies
Help Konica Minolta c351 mac user
One is that the fold and staple option only works on 8.5 x 11 sized paper, thus printing onto a 11x17 spread and then folding. If letter paper is not selected, that will grey it out.
Nov 03, 2008 | Konica Minolta bizhub C351 All-In-One...
Staple problem
Are you sure you have the correct sorter, they come with diff. options. the same model comes w/wo staples- w/wo book binding etc.
For example : w staples may be an AOor A1 model
wo maybe an AS or B1 model
Jul 17, 2008 | Sharp AR-407 Copier
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
3,662 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
