Question about Canon PowerShot A75 Digital Camera
Camera got wet and is now showing a e-18 message
Camera got wet and is not fucntioning and showing an E18 message
  • Anonymous May 07, 2008
    My camera went into water . For a week it would not work. , Now it will turn on, once in a while. . Message on camera keeps showing ",remove batteries " and" weak batteries." Now camera will not turn on.
    I HAVE TRIED SEVERAL SETS OF NEW BATTERIES. DO YOU HAVE A HELPFUL SUGGESTIONS.? I LOVE THE CAMERA.
    Thank you.
    Problem Solver:
  • 6 Answers
E18 is a general error code for canon. if you got from best buy repost if you got the accidental plan from them
Posted on Apr 29, 2008
When my S2 IS is turned on, the lens moves out, a beeping sound occurs, but the viewfinder remains black except for the message E 18. The lens does not move back in when the off button is pressed.
The Error E18 is quite a havoc on these Canon cameras. Here is a blog with great info on it: E18 Blog
Do not force your lens back into place and don't try and jiggle it either, you will be further damaging other pieces.
This camera is very powerful and the repair is well worth it. Teleplan Camera Repair provides a quote online with the cost clearly displayed.
Aug 04, 2010 | Canon PowerShot S2 IS Digital Camera
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
E 18 message
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 04, 2009 | Canon PowerShot A75 Digital Camera
I have the Canon Power Show S2 IS Digital it's showing E18?
Check out this:     Generic problem for all Digital Cameras E 18 problem
Dec 23, 2008 | Canon PowerShot S2 IS Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 Message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A75 Digital Camera Logo
121 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
