Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Toshiba 46H84 46 in
What should it cost to replace a blue CRT ?
  • Toshiba Master
  • 8,617 Answers
The tube will be around 400.00 and then the repair tech will want maybe 150 to install. Try this link they may be able to get you one some what cheaper and give free tech support so you could install it yourself.
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
Hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
Screen goes blue
If the picture goes Blue, it is probably the BLUE CRT failing. Sony does not make the CRT ASSY available. You must remove the BLUE CRT and send it to Sony so they can replace the CRT on the old COOLENT COULPLER. There are a lot of negatives about doing it. The biggest is the cost. The rebuild will cost about 300.00. Most of the time the RED and GREEN CRT also should be replaced other wise you will have a color imbalance. Now you are talking about 900.00. In short, it is just not cost effect in my opinion.
I hope this helps,
Skyassoc
Nov 15, 2009 | Sony KP-57WV600 57" Rear Projection...
My toshiba 2577db has a blue line across
easy the vertical chip is dead /and or two
caps right next to it , total cost of part 8.00
so dont let them charge you to much if
you take it in to a shop
Jun 28, 2009 | Televison & Video
Blue screen when watching tv
hi,
i contacted toshiba and this what they have recommended, i am concerned whether it will be cost effective to repair.
''The Blue CRT is being driven at maximum brightness, it could be
components in the associated drive circuitry or more likely an internal
Short circuit of the Blue CRT itself.
I have not rectified the problem but would be interested in the cost of repair if any can give me an idea
Hope this helps others as well
regards
chris
May 19, 2009 | Toshiba Televison & Video
Blue doesn't work
replaced the blue crt drive pcb or the large transistor on the crt driver pcb.
Jan 08, 2009 | Toshiba TP50G60 50" Rear Projection...
Toshiba 46H84 Blue CRT Misaligned
The problem is you convergence IC's. STK392-110. If you are not experienced I would contact a tech to do this work. Repair costs should be 200-400 depending where you live.
Dec 08, 2008 | Toshiba 46H84 46" Rear Projection...
Dear sir or madam, I've an industrial display unit(TOSHIBA) which it's CRT is out of order and should be replaced by the new one.the matter is that I couldn't find the particular crt which I'm looking for...
Why would you be looking for a new CRT? Replacement costs dictate a new diplay unit unless the failed CRT is part of a much larger display unit. Call Toshiba. They would know if the CRT is even available.
Nov 29, 2008 | Toshiba 32A33 32" TV
42 toshiba rear pro
burn in is caused when the phosphorus is gone from the face of The CRT . The only way to get rid of it is to replace the afected CRT or have it rebuilt. CRT rebuilders are hard to locate and most rebuilders are almost equal to what a new CRT would cost.
Mar 30, 2008 | Toshiba 43H70 43" Rear Projection...
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
Oct 24, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
