Question about HP DeskJet 656cvr InkJet Printer
Deskjet 656c series printer
I have a paper jam (my own fault!) but do not have rear door access on my printer. How do I unjam it?
I'm afraid my solution was a very untechnical one - I tore off the damaged pieces of paper that I could reach, then spent a very long time gently pulling on individual pieces of paper, which were at first jammed solid, until at last one "gave", and I was able to withdraw the other pieces.
I'm sure there must be an easier way by dismantling something, but I didn't want to do that without advice.
Posted on Apr 30, 2008
How to Fix Paper Jamming Issue in HP Printers?
not sure if this helps...
Skip to the two-sided printing accessory section if you have a two-sided printing accessory instead of a rear access door.
  1. Turn the knob on the rear access door counter-clockwise.
  2. Remove the door. ...
  3. Pull the jammed paper out of the printer. ...
  4. Check to make sure no scraps of paper are stuck in the printer.
More items...
HP Deskjet 900 Printer Series - Clearing a Paper Jam ' HP® Customer ...
or go to this link...
How to Fix Paper Jamming Issue in HP Printers Google Search
Oct 27, 2017 | HP Office Equipment & Supplies
While printing 2 or 3 lines it shows paper jam message. Can't print even a page!!!
make sure you don't have any small pieces of paper stuck in the printer s.gif s.gif s.gif
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door c00108288.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Jan 10, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
My psc 1100 series paper jam. How i can fix
You need to switch off and unplug the printer. Now open the rear access door by pressing in on the left side of the access door and then pulling it toward you. Now check for any paper jams. From the rear access door opening, gently pull any jammed paper out.
Note-- All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
Reattach the rear access door by inserting the two pins on the right of the door into the holes for them, and then pressing in gently but firmly on the left side.
Daniel Scott
Jun 10, 2010 | HP Office Equipment & Supplies
Printer status states paper jam although there is
Have you check the rear side of your printer?
Try the below..maybe it will help...
Disconnect the USB cable or parallel cable from the rear of the product then turn off the printer. Turn the knob on the rear access door counter clockwise, and then pull the door out to remove it.Check if there is any paper there..
May 24, 2010 | HP DeskJet 5550 InkJet Printer
Approx. one third of A4 sheet jammed but can't be seen
Your printer has a rear access door which can be removed by a rotating knob that is recessed . Rotate the knob counter clockwise, and the rear access door will pull out. You should then be able to get at the jammed paper. Reinstall the the access door and you should be good to go.
Mar 17, 2010 | HP DeskJet 960c InkJet Printer
How Do I Reset A HP Deskjet 656c Printer
Itdepends on what youwantto reset.
If it ids due to paper,you pres th epaper advance button that flashes.
If it is for ink you open and close the ink door and then press the on button thet press it again.
Jan 16, 2010 | HP DeskJet 656c InkJet Printer
Paper jammed and torned.cannot remove the paper
If paper is jammed internally, you may need to remove the rear access door to clear the problem.
1) Press power to turn off the printer
2) Follow manual to remove rear access door
3) Remove the jammed paper or any little bits that might interfere with the paper path.
4) Replace rear access door.
5) Power on
Try printing again. I hope this solution helps!
Dec 26, 2009 | HP DeskJet 2600 InkJet Printer
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
Paper jams
actually, was an unintended feature(just kidding) I work on these all the time, and you might find that removing the bottom tray helps a bit to release the lower tension, when you open the rear door.
Jan 16, 2008 | Dell 1710n Laser Printer
HP DeskJet 656cvr InkJet Printer Logo
Ben Johnson
