Question about Ricoh Aficio 450 Copier
Ricoh Aficio 2035e SC542 service code
How can I clear this code? How do I get into service mode? I don't have any manuals for this machine.
Brad
  • 1 more comment
  • bfordz Apr 29, 2008
    Thank You for your assistance. Since submitting this question I've been told "this" particular machine is still under a maintenance contract.
    At least now I know.
  • Anonymous Mar 20, 2014
    Please could someone advise what this code relates to. Please can you also provide exact instructions to reset the machine if it is possible to clear the code. We cannot get into the service mode panel. Please advise how to do this. Thanks
  • Anonymous Mar 30, 2014
    error code j008
    Problem Solver:
  • 13 Answers
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
Why ricoh aficio mp 171 spf is showing servical sc 542?
because in some moment the fusing temperature was more high than the optimal. maybe it is just because of precaution issued the SC542. or maybe is problem . you need to reset the SC542 by entering the service mode. for this if you call service they will charge you big money. so if it is just issued just as precaution by doing the following procedure the machine will work fine again. but if the code do not clear do not repeat the procedure more than ones that you can make bigger damage that it has have before the code. so follow the next procedure: first enter service menu by pressing the following keys in order. press the yellow clear key the pres 107 and then press the red clear/stop key until on he screen write service menu or something other than the usual screen. after that appear. turn the machine of by the left side switch and wait 5 seconds, than turn it in again. if starts to work everything is okey . if the SC542 appear again do not repeat the procedure. call a serice techician
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How to clear sc544 in ricoh aficio 2035e
clear modes- 107-hold down the C button touch system sp-touch sp 5xxx mode-restart the machine. Please clean or if necessary replace the fusing thermistors.
Feb 18, 2015 | Ricoh Office Equipment & Supplies
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Clearing sc542 code
procedure for reset this firstly enter in service mode.
Procedure[ press yellow all clear button>press107>press clear/stop button hold until 4 second. you enter in service mode. than machine off and on.
If your problem is not solve so firstly enter in service mode. than press 1 > select [mode] with up down arrow key> than select [memory all clear] with up down arrow key> press [execute] press OK than machine off and on. or some cases replace thrmister.
Aug 18, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
We had power failure today and now after unplugging it and just turning the power off our Ricoh still has SC542 as an error code- - please let us know as to what we should do- should we try something else...
You should have a service technician come look at the machine. sc542 is a fuser code, which could mean that a thermostat was blown, or it could be a dirty or defective thermistor. A Ricoh technician will be able to inspect the fuser and make that determination, and hopefully get you up and running right away!
Jul 06, 2010 | Ricoh Aficio 2015 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 450 Copier Logo
3,751 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
