Need to empty used ink tank on canon i70 - Office Equipment & Supplies
  • 2 more comments
  • rweber3 Apr 29, 2008
    Thank you but no, I have done that hundreds of times. I am getting the error message that the waste/used ink tank is almost full. I can push "resume button" now and bypass the error, but the manual says that eventually I won't be able to do that and the tank must be emptied and the counter reset. Need to know how to do that without taking it to a service center.
    Thanks,
    Ray
    Thanks,
    Ray
    Thank you Benimur, that seems to have worked for now. I will monitor and let you know if the message comes back.
    Great response and advice.
    Ray
    Thanks,
    Just where is this waste ink tank/pad and how is it removed?
  • 3,037 Answers
All you need to do is replace the ink tank, cleaning it is not wise due to the nature of the ink, it basically is a pad that absorbs the ink and the replacement ink tanks are very cheap I think
you can order them from this link below
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=8720#SNAModelSuppliesAct
Let me know if you have any further questions and I would be glad to help
Posted on Apr 29, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    Waste Ink Counter Reset.
    (1) Turn off the printer.
    (2) Press and hold the RESUME button, then press and hold the POWER button.
    (3) Release the RESUME button, Next press and release the RESUME button
    two(2) more times in succession. Note: you are still holding the POWER
    button). The printer's carriage will “reset" or move momentarily.
    If the above was properly performed the printer will enter the "Service Mode".
    (4) Press the RESUME button 4 times, this will select the clear waste
    ink counter function. The lamp will alternate (change) color with each
    key press. Next press the POWER button to "set" the change, and return
    to the top of the function selection menu. Press the POWER button again
    to restart the printer.
  • Benjamin Patri
    Although the pad can be removed and cleaned (sort of), the ink is
    comprised of very fine particles and consequently it is impossible to
    completely clean the pad.
  • Benjamin Patri
    The difficulty to replace the pad is akin to replacing a toaster oven
    element, a job for any 5 year old. Just be careful. Power the machine
    and open the lid to move the head carriage to the center. Then remove
    power cord. Remove the print carriage from the carrier (not the tanks,
    the whole carriage assembly), by lifting up the gray lever. Put a piece
    of cellophane tape (musn't use the word Scotch) over the head openings
    to protect them from damage and lay the assembly on its side. The ink
    will not run out nor will it dry out.
    The head can be cleaned
    with filtered water after removing the cartridges, just be extremely
    careful not to damage the head surfaces (look at them with a 10x lens
    to see just how small the openings are and how easy it is to damage
    them).
    There are four slots in the back with tabs inside that
    must be depressed in order to free the top. There are two tabs
    underneath that must be pushed in to free the power inlet box (it
    slides up and back, watch out for the wire connector when the box comes
    free). There are two screws that hold the frame to the bottom, one on
    each side near the back corner of the frame. They are gold with a
    washer head. Remove those and lift and wiggle the frame up and out to
    the rear.
    On the right side of the head travel path, where the
    head sits when not printing, are two small pads, one square and one
    rectangular. They are supposed to be white, probably they are black.
    Carefully pluck those out with tweezers and wash them (very inky!!). Be
    careful of the little plastic shields near the pads.
    In the
    chassis box is a narrow thick pad on top of the waste pad. This does
    not seem to collect ink (at least in mine it did not). Remove this and
    then the waste pad.
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Guru:
  • 1,342 Answers
Take out your existing ink cartridges and rinse the sponges well with alcohol. Blot them dry and let them sit a while. Also rinse the screens on the nozzles in the print head/ink tank. Rinse each screen by using a refill syringe then flood the ink tank compartment with a level of alcohol so as to just cover the screens. I let that sit a few minutes then blot dry. Run the cleaning phases.
    Brigadier General:
  • 6,966 Answers
Could it be that you are referring to waste ink reset?
  • 2 more comments
  • Louie  Role
    Louie Role Apr 29, 2008
    Hi again,
    If your concern is doing a reset on the waste ink tank counter, pls follow below procedure:
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
    (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3)
    While holding the Power button, press the Resume/Cancel button 3 times,
    and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4)
    When the LED stops blinking and lights in green, press the
    Resume/Cancel button 4 times (Each time the Resume/Cancel button is
    with orange.) After the function (menu) is selected, press the
    Power button. The LED lights in green, and the selected function is
    performed. (When the operation completes, the printer returns to the
    menu selection mode automatically.)
    *** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
    This was originally posted here.
    Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
  • Louie  Role
    Ray, have you tried the reset procedure I have posted?
  • Louie  Role
    Great, pls post back for any further development. Cheers.
  • Louie  Role
    Louie Role Apr 30, 2008
    Ray,
    As others have indicated, the waste ink pad is a sponge like materials used to be white but would expectedly be black now. it normally sits below the printheads when they are in their parked position.
  • 563 Answers
Hi rweber3
It take it you meant that you have to replace the cartridge ?
Simply open up the top cover and take out the old ink cartridge ( normally clips in and out ) and replace with the new.
If you have any further queries , feel free to post us another thread.
Thanks for using Fixya !
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Large black ink tank is empty but I cannot activate the smaller
This "photo" printer has two separate BLACK inks -- one using vegetable dyes, and one using suspended carbon micro-dots, in order to get the "best-possible" BLACK colour.
Replace the empty cartridge.
Jul 26, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Waste ink tank full. how do i fix?
you try to head cleaning
i hope i can help you
Sep 03, 2009 | Canon BubbleJet i70 InkJet Photo Printer
Empty the overflo ink tank on a canon ip5000 printer
The waste ink absorbers on a Canon are pads that are under the print engine and cover the whole bottom. It is a major dissasembly where the covers come off, cables and plugs un plugged, power supply removed, and then you need a shop to reset the counters.
Aug 28, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
Jul 05, 2008 | Canon BubbleJet i70 InkJet Photo Printer
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
green.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
Variable ink darkness
If the printer has been used exrensively then its probably the printhead that needs replacing. The i70 printer uses a QY6-0046-000 Canon Printhead Printheads are available from many sites on-line and thru PC World
Sep 06, 2006 | Cannon i70 Printer
35 people viewed this question
