Hello. I have a notebook fujitsu siemens amilo 1505 pi, and the keyboard, is not working properly, the keys m and n are not working all the time. What should I do?
change keyboard is a function of operacional system:
Step 1: identify the layout> american, universal, european?
Step 2: click on keyboard icon>rigth side on task bar> choose the correct layout and language
Step 3: setup as Default
Step 4: sometimes the reboot is needed.
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right Fujitsu Siemens Amilo K Series ---- Not Wireless Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Prise up the keyboard using a blunt knife,there is a metal plate below the keyboard held by clips, the keyboard will pop out giving access to the memory slot below,the keyboard can then be pressed back in place to re-locate the plate on the clips! I used a a knife from a dinner set that has a round blunt tip!
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
