Hisense remote does not work with hisense tv
Hi guys! I have a Hisense tl3220hd tv. I have two identical remote controls (both Hisense HYDFSR-A205EA), and I can't get either to work with the tv. Any advice on how I can reprogram the remote?
  • 1 more comment
  • SandraFixya May 07, 2008
    Thank you for your response, but it didn't work just yet. Here are the steps I took:
    1) Went to http://www.hifi-remote.com/ofa/codes-tv.... but Hisense is not listed as a TV brand there, so there's no code.
    2) Hit "TV1" on my remote; the red light blinked. Then I held down the "set" button (there is no "setup" button"). I kept holding "set" but the red LED did not blink at all, let alone twice.
    Any more ideas?
  • Anonymous Mar 15, 2014
    New remote won't display a thing on Hisense TV. How do I get it to do so in order for me to do step 1,2 & 3 Many thanks.
  • Anonymous Mar 18, 2014
    Hisense remote stopped working
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Looks like the remotes are kaput. Get yourself a universal remote and try this:
      codes.
    Blinking Back the Code:
    1. PRESS the device, (TV, VCR, CABLE, etc.), button - RELEASE
      then RELEASE.
    3. PRESS 9 - 9 - 0.
    4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
    5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
    6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
    7. PRESS 4, carefully COUNT the number of blinks. (4th digit)
    If the remote DOES NOT blink it means the number is 0.
    This is your 4-digit setup code.
    http://www.hifi-remote.com/manuals/ofa-l...
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Oct 17, 2008 | Hisense TC24FS2H TV
What is th? code for a sky remote to work a hisense smart tv
Hi Hans, Unfortunately that remote control will NOT work on a hisense television... The link below is a sky remote control codes site, Scroll down the list and HISENSE isn't on the 3 or 4 digit list. Sorry mate......
Sky Remote Codes
Apr 05, 2016 | Hisense Televison & Video
Need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Remote control code for a Comcast remote, Hisense LHDN32V tv, code in maual 10748 doesnt work.
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
May 03, 2011 | Televison & Video
Locked remote
i know this may sound silly but check the batteries. now if you allready changed them and your still having the same problem check the ir signal on the remote. now all you have to do is take any camera( camera phones work just as good) hold it to the ir sender on the remote press any button on the remote and look through the view finder on the camera. you should now see a light go off on the remote through the camera. if you dont see a light then you have yourself a broken remote. if you do then its possible its the tv ir reciever. and may need to be serviced. but hoping its the remote you can always get a replacment remote for cheep.
Jan 26, 2009 | Hisense TC24FS2H TV
Programming remote to hisense tv model # LCD1504US
Cable remotes and TV remotes often are incompatible.
Sep 27, 2017 | Hisense LCD1504 15 in. Television
Televison & Video Logo
5,387 people viewed this question
Top Televison & Video Experts
