On my old Micron Computer, windows 98 freezes on the splash screne. The bar on the bottom continues to indicate that it is loading but after leaving it for 3 hours, nothing changed. I recently removed the battery and had to reconfigure the BIOS. Since there was an arbitraty password on it. Is this problem most likely due to a virus on windows or an error in the BIOS?
  • 4 Answers
I doubt its a virus on windows. it is most likely a problem with the bios file.
Posted on Apr 29, 2008
Computer screne is black,,d sub comes up and
Sounds to me as though the backlight has gone faulty on your screen. It will need to be repaired or replaced I am afraid.
Sep 21, 2014 | Computers & Internet
Swapping hard drives won't boot windows
do 1 thing 1st you formet your hard drive if its done ite mean your hard drive ok and install it again . i mean OS. if not formet then submit your hard drive in service center or bye new 1. ple done if you r happy.
Jan 29, 2010 | Microsoft Windows 2000 Professional for PC
My computer wont load pass windows screen it just freezes and dont load???
do a power drain...take out the ac adapter and the battery and then press and hold down the power button for 1 min....
then go to the BIOS screen and set a BIOS default...
then do a bios update from your computer's manufacturer's homepage...
Oct 23, 2009 | Computers & Internet
Windows XP freezes at startup
Some files can be missing, try to start your computer in SAFE-mode, if it works you can try again, othervise you have to repair you XP-version. Add me david.vk@live.se for more instructions.
Jul 08, 2009 | Microsoft Windows XP Professional SP3 Full...
OS does not work in pc
The Windows 98 option seems to be DOS-only. You could try typing WIN or WINDOWS at that C:\> prompt.
For Windows XP, you can try a few things:
1. Boot into Windows XP, but hit F8 BEFORE the splash screen (with the scrolling bar) appears. You will get a menu. Try Start with last known good configuration. See if it boots. If not, repeat, but choose Safe Mode. If it will not boot in Safe Mode, you have a more serious problem. Continue to 2....
2. Insert your Windows XP CD in the CD-ROM drive (you need to have your BIOS set to boot from CD first, or look at the POST screen for an option that lets you select boot device). If it asks, press a key to boot from CD. Let it load. First off, try pressing R to go into the recovery console. Follow the instructions. When it asks you which Windows you want to log on to, choose the appropriate one. When it asks for a password, try just pressing Enter (return). If that works, you will get a prompt similar to the Windows 98 screen. Here, try the following:
CHKDSK /r
(this will take a while - just leave it. Note that you may see it restart the % count up to 5 times. You'll get a report the prompt again when it is finished. Hopefully it says it repaired one or more errors)
FIXBOOT
(say Y to the question)
Now reboot. If you get the menu screen again, don't choose safe mode or last good configuration, choose Start Windows normally.
If this doesn't work, you either have a badly damaged Windows install or a hardware fault. You could try booting into the Windows CD and doing a repair install. Where you pressed R before, press ENTER. Follow the on-screen instructions - you want to do a repair install.
Apr 20, 2009 | Computers & Internet
It wont load the desktop screne
Try starting it in safe mode.....press F8 as the computer first starts up and use the advanced options menu to select 'Safe Mode'
Once in SM....go to >>start>>>programs>>>
accessories>>system tools>>system restore
Choose a restore date before the problem started
Mar 14, 2009 | Dell Inspiron 531s Desktop Computer
Toshiba L300D-18E... won't load up past splash screen
Less than four months old (still in warranty), just back from hard drive replacement (recent service issue). Take/send it back as this is a warranty issue.
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Reloading windows 98 on a Panasonic Toughbook CF37
http://support.microsoft.com/kb/262381/en-us
Restart in Safe Mode and Use Msconfig.exe loadTOCNode(2, 'resolution'); Restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then choose Safe Mode from the Startup menu. For additional information about Windows 98 startup, click the article number below to view the article in the Microsoft Knowledge Base: 178548 (http://support.microsoft.com/kb/178548/EN-US/) No 'Starting Windows 98' Message at Startup After your computer restarts in Safe mode, use the System Configuration Utility tool (Msconfig.exe) to minimize conflicts that may prevent your computer from finishing Setup.
To start and use the System Information tool: 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Information. 2. On the Tools menu, click System Configuration Utility. 3. On the General tab, click Selective Startup, and then click to clear the following check boxes: • Process Config.sys FileProcess Autoexec.bat FileProcess Winstart.bat File (if available) • Process System.ini FileProcess Win.ini FileLoad Startup Group Items
Dec 05, 2007 | Computers & Internet
AMD XP2400+ with K7S41GX
Hi, the only reason that comes to mind here is your version of XP. A retail version will load on almost anything, a version supplied with a brand name computer may only be suitable for that brand, Dell/HP etc. Sorry if I am not much help, don't discard your old board, you could buy an add on card for ide connection then disable the onboard one and continue with the old system. Goodluck mistyman
Sep 09, 2007 | Asrock K7S41GX Motherboard
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
