Monitor Problems Hello, I am having problems with my monitor.The colors are way to dark.My green shows color as a light lime color and my blue shows as a purple and the red is way to dark, so how can I fix the problem?
  • 106 Answers
1. check the monitor on other PC if the problem is same that means the VGA cord or the Pins have gone faulty.
2. Just bend and cable and keep monitoring the display where it stablises to normal, and tie thw cacle at that point with something.
Posted on Apr 29, 2008
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
I have a "dinosaur" type E-Machines monitor,I've
That sounds like a picture tubeproblem and because to the cost of these old monitors it is cheaper just to buy a new flat screen than to try and repair that old one.
Feb 23, 2011 | E-Machines W3400 PC Desktop
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My monitor is not showing the proper colors. Green is showing up as yellow and red is as dark as black. When I unplug my monitor and the check cable message pops up, the red, green, and blue show up...
Do not put your speaker near your monitor and any device that have magnet on it. It will damage your monitor colors. If degaussing it not helps you, you can try to use your speaker. Move again your speaker near your monitor and use its magnet to remove the color scattered on your screen. Check also your cable connections. IT might some pins was skewed up. Don't open your monitor own your own. It's hazardous. It still holds thousands of voltage even not connected to the outlet. Bring it to professional if do you think you can't solve it own your own.
Jan 27, 2010 | Dell E771MM 17" CRT Monitor
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
I have a blue line in my monitor
line driver element defective. no repair possible, to my knowledge. replace LCD or ignore line.
Mar 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Mar 16, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
No yellow or blue color displaying
In a monitor like crt type. there are three colors amplifier. Red, Green and Blue. I think the Blue color amplifier is defective. Try check the biasing and also the transistor.
Feb 02, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor problem
You didn't specify the card you are running but here is how I would approach the issue.
#1 refurburished Monitors have at a minimum a 90 day warranty, so be prepared to call Dell Tech Support and troubleshoot if my information doesn't help, if the monitor is defective, then they will have to exchange it.
#2 The optimal Resolution is 1680 x 1050 60 hz, you need to ensure that setting (You didn't specify, so I mentioned it)
#3 Sometimes color issues are caused by cabling issues. Try both DVI and VGA connections, see if there is any difference between them (digital or analog, the picture should look the same) If one looks ok, the other doesn't. then it may be a bad cable.
#4 Does the issue occur on more than one system. If it does, then the monitor is bad. If you have individual pixels stuck on (Red, Green or Blue) and you have more than 6, that in itself is justification for replacement.
#5 If all the above doesn't work, contact Dell Tech support for an EXG
Jun 08, 2008 | Dell E207WFP LCD Monitor
Open Questions:
Computers & Internet Logo
David Payne
David Payne
