First Option:Please change The Phone Bettery and charger and check The check The Phone charging IF Charging Problem will Not Solved So Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
Dear Friend,
I hope this will help you..
Your Light problem may be Caused Due to Water Damage(NO LIGHT).Then you have to Clear your Hardware Area.
Clean Light IC
Then Check phone
Still Problem Exist
Change Light IC
You can Repair Click here
(NB:Changing Light IC is Better to do by a Professional. Improper handling may lead to total Damage. )
IF THIS HELPED YOU in any way DO RATE ME...
Thanks For Using FixYa
Jai Sing,
How do you know it is the IC that has gone? and which IC? each function has its own IC.
If it indeed has gone then your phone will be scrapped by Nokia. It becomes uneconomical to repair busted ICs. Buy a new phone as even Nokia will not repair it. If the phone still works, then use it till it works.
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
