Question about SanDisk Sansa e250 MP3 Player
It freezes My mp3 works until I go to play music and there must be a bad track that freezes it, I have to hold the button 10+ seconds to restart it, I have gone to my computer and tried to delete the music files to start from scratch. There are 3 files that I am unable to delete, for whatever reason. I am trying to salvage this and am at my wits end!
  • Chinn Chinn Apr 30, 2008
    I have the same problem i even tryed to delete it off the play list it was original sync'd from and that didn't even work! %#@& itz so frustrating!
Have you tried removing the battery when it freezes? Sorry I can't be more help
Posted on Apr 30, 2008
Music is unable to play
You may need to restart the ipod
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
But if this does not work go to http://www.apple.com/support/ipod/five_rs/nano3gen/#
Dec 27, 2013 | Apple iPod nano
My GC-821 pink mp3 player says ''no file'' after I synced my music (from windows media player). But it plays the music back to me on windows media player. Help!
Do NOT open the "RECORD" folder and put your music in it.
Put you music in the folder that opens. the "RECORD" folder is NOT for you to put music into. It is for you to get your .WAV recordings out of.
Ohhhhh, now you get it!!!!
Dec 16, 2009 | Element Electronics Audio Players &...
Ipod 1gb nano
When you plug it in to your computer, you should see an option in iTunes to synchronize it with your current library. Press "Yes" and the existing music will be erased.
You should be able to turn it off by holding down the "Play" button and turn it on by pressing the "Play" button.
If this fails, you can restart the device by holding the "Menu" and "Select" buttons for 6-10 seconds until it restarts.
Sep 18, 2009 | Apple iPod nano
Bad Track
You will probably have to reformat the player, but the "bad track" message could also be caused if the songs you are trying to download have an expired DRM license.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa E280 MP3 Player
MSC MODE AND MTP MODE
-Tha Mp3 Doctor
Oct 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Bad Track Fix.....
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e250 MP3 Player
It won't let me play my music!
no worries. there may be a read error. if it still connects to your computer fine download all of the files, movies, mp3, mp4 etc back onto your computer. once you have done this go into the file holding all of the mp3's and set the file to show details and look for a mp3 that is the incorrect file size... in general comparison to the other files. also if the device came with software look around for a restore factory settings button or wizard, and once the device is completely clear restart it and reload the files back onto it, remove the device (safely) then switch it off and back on and then try it out again. hope things work out bro.
Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
How to use MP6410
to turn it on hold the play button for aboot 6 seconds or until it comes on all the other buttons are self explanitory. to put music on it you have to connect it to the computer while it is on. then to torn it off hold the play button until it shuts off.(aboot 10 seconds) hope i helped-ed
Jan 31, 2007 | Classic Electronics MP6410 MP3 Player
Sony NW-S23 256 MP3 Player
try holding down every button indicidualy for 2 seconds
Jun 24, 2006 | Sony NW-S23 256 MB MP3 Player
SanDisk Sansa e250 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
