I have a boss diablo series 600.2 1200 watts mosfet it stays on protect mode all the time i dont even connect the subs and it stays on protect mode as soon as i turn it on wat could be the problem please help me thanku
Chances are your speakers are running at to low of impedance. Check if your running aftermarket. speakers, if so they are probably wired in parralle. Change the wiring to "series"increasingly your impedance from 2ohms to 8, that should solve your issue.
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
If your amp started smoking, probably not. Due to your description, did the other sub really blow? I would hook it up to another amp to test it. It may have been a channel in your amp. As for repairing the amp, the parts and labor to repair will probably cost you more that to just replace the amp.
wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
11-1/8"W x 2-3/8"H x 9-7/8"D
Wire your sub in bridged mode (4 ohm mono)
+ to + on amplifier
- to - on amplifier
(using bridging terminals)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
most amps are self explanatory just look at the outside edges where the wires go into the amp and they are usually printed positive remote negative and so on with the speakers
Make sure the BOSS isn't in "Protected" mode (Red led lit) and connect the speakers properly (check the connections if they are in "bridged" mode). Also, make sure you set the cross-over, bass boost setting, bass volume control and the bridge mode according to the speakers you are connecting. Check the input level too. The BOSS amplifiers are of very poor quality and it can be easily broken. Maybe yours is broken.
