Question about Cameras
The camera won't boot up. When you turn it on it says "turn the power on and off again". After several hundred trys I give up. It powers itself off after 1-2 minutes. None of the controls work except the power button. The camera is a Sony Cybershot 7.2 bought in 12/07.
Throw it in the garbage
Posted on Jun 17, 2008
1999 Nissan Pathfinder won't start.
if engine management light lit up on dashboard you will need an obd scanner that then gives you the code to what is wrong.
Dec 26, 2016 | Nissan Cars & Trucks
Tip
How to Reset BIOS on the GA-X58A-UD3RMotherboards often include hundreds of...
How to Reset BIOS on the GA-X58A-UD3R<span style="font-style: italic;">Motherboards often include hundreds of settings in the BIOS to adjust the performance and stability of your computer. Many of these settings, when improperly configured, can prevent the computer from booting. The traditional way of resetting the BIOS when it doesn't boot is to open the case and place a jumper on the motherboard or remove the battery for several minutes. Most newer motherboards include a reset button near the peripheral ports. The Gigabyte GA-X58A-UD3R uses this more convenient method.</span><br /><br /> <span>Instructions</span> <ol style="font-style: italic;"> <li>Power down your computer by selecting "Shut down" in the Windows task bar or press the power button on your case for four seconds. Leave the power cable plugged in and the switch on the back of your case in the "On" position.</li> <li>Press the "Clr CMOS" button on the back of your computer for five seconds until the computer boots. The button is located with the peripheral ports between a USB port and the coaxial S/PDIF port.</li> <li>Press the "Delete" key when your computer starts up to enter the BIOS setup.</li></ol> <ul style="font-weight: bold;"> <li>Pressing the "Clr CMOS" button while the computer is powered on could result in data loss.</li></ul><br /> <span><span>References</span></span><a href="http://download.gigabyte.us/FileList/Manual/mb_manual_ga-x58a-ud3r_v2.0_e.pdf">GA-X58A-UD3R USER MANUAL</a><br /><br /><br />*please leave a ratings if this information is helpful and beneficial to you.<br /><br /><br />Regards<br />MultilinkEnt. <br /><br /><br />
on Jul 09, 2011 | Computers & Internet
I have an hp dm3-1130us laptop with Win 7. I haven't had problems with it until today. I have it set to sleep when I close the screen which I did, but when I opened it and it turned back on it only...
http://www.hp.com/ctg/Manual/c01893277.pdf
See chapter 5, Also read the part about setting or disabling the processor sleep mode, Disable it. IF it boots normally
Go to Start. In the search box type "Device Manager" (without the quotes) - and then press Enter; this will open up the Device Manager. Double click on 'Universal Serial Bus controllers.' Now you will see a list of 'USB Root Hub'. Right-click the top one of these and select 'Properties'. Click on the Power Management tab, un-tick where it says 'Allow the computer to turn off this device to save power' and click 'OK'. Now repeat this action on the other 'USB Root Hub' items in the list. when they are all done you can close the Device Manager, and your USB mouse and keyboard will now be able to re-awake your computer
Mar 17, 2017 | Computers & Internet
Acer MS2211 won't boot. Starts and beeps 2 times. Trys twice then turns off.
take out the memory sticks and replace them and try again.
Nov 16, 2012 | Computers & Internet
Kodak c340 won't turn on
Hello Carol, Are these batteries new and name brand ? It sure sounds like low battery power, Those cheap batteries found in some stores do not have the energy to boot a camera even when new out of the package. The camera has a very high demand to start up. I own several cameras that will not turn on with brand new cheap batteries.
Best Regards, Russell
Oct 28, 2012 | Kodak EasyShare C340 Digital Camera
I have a Windows CE Sylvania netbook that won't boot to the desktop. I can turn it on, but it seems to freeze right as it turns on. It shows the start up screen where it says "Loading OS Image...
One temporary solution is to remove the battery for a while until all the capacitors in the unit discharge. Upon replacing the battery, you get one good power up try. Notice that the date and time have reset. Once you turn off the unit and try to power it up again, the problem comes back and you must again remove the battery for a while. There may be a patch to fix the boot loader, but I have not found it yet.
Jun 15, 2011 | Computers & Internet
My SX30 IS turn on automatically while inside the box then just "die" down. As a result, the lens stuck up and the camera won't power up. My solution is re-charge the battery and it turns...
Hiof course not. you have a problem camera. like the type of problem it could involve several circuit trouble shoot. First power control pcb (dc/dc convertor), on/off control switch fpc, and main pcb. I suggest you to send canonUSA or your local repair shop. ( That must be under warrenty, it is pretty new product) Both place would take time in those type of problem. CanonUSA 2 to 3 week usuallly, local 1 to many week depand on what they want to repair.
Jun 02, 2011 | Canon PowerShot SX30 IS Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Cameras Logo
219 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
