Question about NetGear DG834G Router
New pass word
I have been running a net gear router on aol untill it stoped working i had changed my aol password to a new onw then the router stoped working now im told i have to put the new password in to the router but i have tried aol how they told me and it wont go into the router
    New Friend:
The sight is not helping
Posted on Dec 17, 2013
You have to go into the router settings by open internet explorer and click in the address bar and type http:\\192.168.0.1
the user name should be admin and the password is password
when the setup screen loads in the left of the screen their is a blue box click basic set up there should be a bit with your aol user name and password in the password box enter the new password
then click apply at bottom of the page
Posted on May 11, 2008
Have you tried resetting the router back to factory settings using the small hole in the rear? This will default it back as it was when you first got it.After doing this you would have to put all your original settings back into it though.
Posted on Apr 29, 2008
Need to change login and pass word for my net gear royuer wndr3700
If it is set to the default the username should be "admin" and the password should be either "admin" or "password". If they have been changed and you cannot access it, you will have to factory reset it by holding the reset button down for 10-15 seconds then access it using the credentils above.
Dec 09, 2013 | Linksys Computers & Internet
Net gear wireless router N150 router WNR1000
Looking for the NETGEAR WNR1000 default password?
You probably have little reason to access your router on a regular basis so don't feel too bad
f you've forgotten the WNR1000 default password.
However, when you're troubleshooting a network problem and need to get in to the device,
the WNR1000 default password suddenly becomes very important.
For most versions of the NETGEAR WNR1000, the default password is password. As with most passwords,
the WNR1000 default password is case sensitive
Be sure to change the default router password on your WNR1000 to something more secure as soon as you're in.
Then use a free password manager so you'll never forget your new WNR1000 password
hope this helps
Jul 25, 2012 | NetGear WGR614 Wireless Router
Pass code
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
Jul 04, 2012 | Computers & Internet
I have a net gear router. I left my wep key in Canada - I am now in Florida. My husband needs to connect to my network but I don't have the wep key for him to enter in his computer to allow him to connect...
Access the set-up page of your router. Here's how to do it.
1. Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" (without the quotes) and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
2. Enter the username "admin" (again, without the quotes), and the password "password" in the appropriate fields, then click OK to login. If that password fails, try "1234," "Password" (with a capital "P"), or "admin" until you are greeted with the settings screen
3. Make any required changes to the settings. Under security, it is possible to specify a new username and password for added security. Once you are done, close the window, and the system will automatically log you out.
  • Nov 08, 2010 | Computers & Internet
    Need a securty code
    Regarding your concern, please note that in order to get the network key/password on the NETGEAR router (MODEL_NUMBER), we need to login to the router's web interface using any computer which is physically connected to the router.
    Please follow the steps on a computer connected to the router using an Ethernet cable in order to find the network/security key:
    1. Open the browser (like Internet Explorer, Mozilla Firefox, or Safari).
    2. Access the router, usually by typing 'http://192.168.1.1', 'http://www.routerlogin.net' or 'http://www.routerlogin.com' in the address bar.
    3. When prompted for Username and Password please enter Username as 'admin' and Password as 'password' (please note that both Username and Password are case sensitive).
    4. Click on Wireless Settings' under Setup from the left menu.
    5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
    6. If WPA-PSK is selected, copy the code entered in the pass phrase.
    7. If WEP is selected, copy the code entered in the key that has been checked.
    This is the code required for connecting the wireless computer to the NETGEAR router's wireless network.
    In some cases, for security reasons the pass phrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
    Feb 07, 2010 | NetGear WGR614 Router
    I GOT A NET GEAR WIRELESS ROUGHTER AND LOST THE BOOKLET AND CANT GET IT TO PICK UP A SIGNSAL OR PASS WORD FOR I POD TOUCH
    netgear www.router.com www.router.net 129.168.1.1
    any above addresses to get into the router put in the password and user name defualt is admin and password is password.
    Go into the wiress security on the left hane pane select that create a pass key or phrase make sure its set for 64 bits and you should be fine.
    Thanks please do rate.
    Jan 13, 2010 | Apple iPod touch
    How do I set up my wirelesss netgear. i have cable vision with internet  and  I have a router that my laptop picks up on but it wont open page to aol or anything Do I plug cable into motem and...
    Open any web browser, such asInternet Explorer or Mozilla Firefox. In the address bar, enter"192.168.0.1" (without the quotes) and press the enter key. This willbring up the login prompt for most Netgear wireless routers. If that doesn'twork, try "www.routerlogin.net", "192.168.0.5", or"10.1.10.1" until the login window appears.
    Enter the username "admin"(again, without the quotes), and the password "password" in theappropriate fields, then click OK to login. If that password fails, try"1234," "Password" (with a capital "P"), or"admin" until you are greeted with the settings screen.
    Make any required changes to thesettings. Under security, it is possible to specify a new username and passwordfor added security. Once you are done, close the window, and the system willautomatically log you out.
    Dec 16, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
    I have a i touch it asl for a pass word for my wireless router
    The default password in the user manual or printed on the label on the device. If you router truly is a WNR834B, then the default login details are:
    userid = admin
    password = password
    If you or someone else has changed the default password, then only that person will know what it is.
    If the password is lost, you can only perform a hard reset on the router and re-enter ALL the settings and configuration, as it will be blank, like it came out of the factory.
    Apr 21, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
    NetGear DG834G Router Logo
    141 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
