Question about Video Game Consoles & Games
Not booting up fan catching inside - Video Game Consoles & Games
    Sergeant:
    Champion:
  • 427 Answers
For any console that has a non-working fan, i would suggest sending it to the retrailer for a new one or have it repaired. If you want to upgrade, you can find companies on the internet that will install more powerful fans for you.
Posted on Apr 29, 2008
Can't open boot on a x reg renault megane scenic
Most likley to be the micro switch in the boot quite common, u can open from inside if I remember correctly where the boot latch is in the centre the bit that keeps the boot closed on the left of the catch there is a little lever u can use a spike to open it , if it's not there there will be a little lever somewhere on the catch that opens the boot
Jan 29, 2015 | Renault Cars & Trucks
I have a brand new pannasonic microwave and when we turned it on it sounds like somthing is catching the fan? Does it have safty bolts in the back that need removing first ( bit like a washing machine)?
no it may sound like a wire is catching the fan when its turned on PLEASE BE SAFE WHEN OPENING! when or if you open the microwave make sure that its unplugged first and that its safely unable to turn on inside try moving the wires away from the fan and place the cover back on safely and make sure its snug and tight back to as it was otherwise it may leak some radio waves out into the house i've rarely seen a few times where the wire catches the fan and opened em up to move the cord away also make sure the fan moves freely
May 26, 2014 | Washing Machines
Error code 20
Is it an E20 error code? The E20 error code is usually something clogging the pump system follow these steps to check. From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yes, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside and remove any thing that does not belong, reassemble ant test.
Nov 25, 2013 | Frigidaire Washing Machines
Boot won't close and hold.faulty catch in lock mech... Key and central locking works but the catch won't hold
with the boot open use a screwdriver to trip the catch and see if it will hold the screwdriver. if it does make sure that the seals around the boot edge are all in proper place. if it won't hold the driver then the catch will need to be replaced.
Aug 19, 2013 | Vehicle Parts & Accessories
How do I remove/replace the ram modules on compaq persario V2000?
Just remove the power cord, remove the case, then you will see the memory inside the slots. Release the catches on both ends of the memory then pull it out.
Maybe one of the memory chips is bad or one of the slots is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 02, 2012 | HP Compaq dc5000 Small Form Factor PC...
Hi my boot will only close after i slam it a few times
The catch mounted in the trunk has a little adjustability. Loosen it and pull it up, retighten. this should solve your problem
May 05, 2011 | 2003 Ford Focus
I have a build up of ice in the fridge compartment and inside, the fan is catching it as well.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Mar 31, 2011 | Samsung RS2556 Side by Side Refrigerator
Why would an audi a4 boot alarm keep sounding. Does it matter that the spare wheel has been taken out for repair?
Audi A4 1.8T Avant 190 S-Line Quattro. Rear washer is leaking down the inside of the bootlid, and as it is right in the centre it is running down on to the boot catch and causing the boot catch sensor to think the boot is open when it isnt.
Can anyone tell me how to get the panelling off the inside of the boot lid and also, if i dry out the motor and reconnect the pipes etc, will everything come right??
Oct 28, 2009 | 2002 Audi A4
Central locking on bmw 318i boot won't lock after pressing lock button?
simple your mechanism on the inside of the boot(catch mech) is spring loaded.just spray copious amounts of wd40 deep inside. if that dosent work then your catch/keep is twisted.
Oct 31, 2008 | 1999 BMW 318 ti
My Mazda
hi see how difficult it is to get the rear panels are to remove from inside the car and get into the boot that way once in its just a case of unbolting the boot catch then sort the boot lock out a matter of interest this is not a old car can you here the boot catch operate when you press the button if so get somebody to pull the boot up while you press the button if not it may be a fused line in this case it is worth checking all the fuses are ok best of luck let me know how you go on yates210456
Oct 02, 2008 | 2004 Mazda 6
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
