Question about Motorola Mobility SLVR L7 Cellular Phone
Motorola SLVR problem
I am facing some problem in my my phone .When i open some photo It saying that file is corrupted and if i select yes for delete file it will delete but after some time it appears again. Idont know what is the problem actually .... And if i store any photo or music file in memmory card it wont store permenently. Some timestemerorly it save and then it will show file corrupted...
canu please help me .....
Thanks in advance
  • 63 Answers
Your need to do a master clear on your phone...you probably downloaded a bad file from somewhere or someone and it has corrupted all u r other files.you would loose most if not all of your download stuff but this should solve the problem...
sam !
Posted on May 11, 2008
How can i save the theme in my motorola slvr l7??....
To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
Nov 19, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My motorola slvr l7 will not accept files, says files too large. also my phone wont format the memory card (2GB sandisk). please help
the space in your memory card might be not enought to receive a file and save. if the phone is not formatting the memory card,use a card reader.
Aug 17, 2009 | Motorola Mobility SLVR L7 Cellular Phone
How to install theme in motorola slvr l7
Mar 23, 2009 | Motorola Mobility SLVR L7 Cellular Phone
I need a master reset codef or motorola slvr l7, and i would like to know how to download a media player for my phone, 'cause i would love to make it more than asimple phone
Try this.
1. From the standby screen, select Menu.
2. Select Settings
3. Select Initial Setup
4. Select Master Reset
5. Enter the security code, then select Yes to reset the device. Note: The default security code is 000000
Feb 02, 2009 | Motorola Mobility SLVR L7 Cellular Phone
In my motorola slvr phone some images doesn't open.
the files maybe much larger for the motorola to hold than the nokia
Dec 21, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Flashing L7
Could be that the file you were trying to flash was corrupt and ended up screwing up your firmware. Unfortunatley, I have no other advice than to take it to a service center for repairs, or installing a new board..
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How to download themes to SLVR L-7
How to install skins/themes on Motorola Phones
Tutorial:
1) Download P2K Commander (make sure the archive has the p2kdrivers folder). Unzip and run P2KCommander .
2) Point your Device Manager to the p2kdrivers folder and install the Motorola MCU
Data logger, etc... devices.
3) If your skin folder has a 'install_yourskin.p2kc' file, just click it and P2KCommander will install the skin.
4) If the install.p2kc file is missing read below:
- Open P2KTools
- Plug Your Phone on the Cable
* On E398, V635 I sugest take the
TransFlash off
- When the status apear 'Connected'
- Hit 'Refresh' to get the file list.
- Select the folder 'Skins'
- Right Click on the folder 'Skins' Will apear a sub-menu
Select the option 'Create Folder'
- Put the Name of the Skin, must be the same name of the '*.ski' File!
- Hit 'Refresh' to get the new file list.
- Select the new folder that was cereated. (The one that contain the same name of the *.ski)
- Hit 'Upload' to upload the skin files to the
phone.
- Select all the files with *.DAT and *.Ski Extension
- Hit 'Open' to Upload
- Wait a Minute while P2KTools Send the files to your phone.
- Select the folder 'Picture'
- Hit 'Upload'
- Select the wallpaper and
Screen Saver of the skin
Done it, restart your phone and check out your new skin..
Link HERE
Jan 15, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Antivirus software for motorola SLVR L7
No the files are not good so always use signed applications okkk and no virus sttack if u worried scan it from pc
Nov 26, 2007 | Motorola Mobility SLVR L7 Cellular Phone
When a ringtone is bluetoothed to me, it shows file is corrupt
you need to do a master clear on your phone ... you would loose ur pictures and any downloaded stuff, but your wouldn't get that file corrupt error again. Somehow your software probably got a glitch.Try the master clear or the master reset in settings and hopefully as i said this would clear the problem. You can then go ahead and try to bluetooth any files your want to. Sam !
Sep 02, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Memory card or camera
See if you can borrow another memory card and try it - pretty sure that is the problem. Also try your card into a different machine with a different card reader - unlikely to help, but if it does then the card is fine and the problem is probably with your card reader (or the cable connection if you are using it). Also check visually in the memory card slot for anything unusual. Hope this helps :)
Mar 17, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Motorola Mobility SLVR L7 Cellular Phone Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
