Question about CTX Optoma EzPro 610H Multimedia Projector
How can I adjust my screen as of now one side is high and one is low,please help
  • stephun May 28, 2008
    my screen is showing double letters how can i make the words come together and not look like to words
  • 563 Answers
Hi dave4455_uk
You will see two feet on the bottom of the Projector that can be adjusted for height purposes.
Thanks for using Fixya !
Posted on Apr 29, 2008
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
Jan 24, 2016 | Cars & Trucks
I have a Poulan Pro High Output Engine that won't start, I've replaced spark plug and filter but still no luck getting it to start. When and if I get it started it idles high and when
Carb adjustment. Start with 1 full turn out on both low and high side. If it fall on it's face, turn the low side out an additional 1/4 turn.
Sep 27, 2014 | Poulan Garden
Carburetor adjustments
what model??? but rule of thumb, 1 full turn out on low side, 3/4's out for high side. then adjust the low side first after warmed up then high side with unit at full speed
Dec 28, 2013 | Garden
What is the factory setting for lowand high screws on 25cc craftsman blower
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Nov 20, 2013 | Garden
How do I adjust the low beam headlght on a 2006 Sabaru Tribecca B9
I have a similar problem. The adjustment screw adjusts both the high and lof beams. After changing the passenger side low beam, both sides then pointed at the ground. High beams were fine. I adjusted so the low beams are fine but now the high beams point straight up.
In talking with Subaru Service he said there is a "module". He said after changing the bulbs they should point down then auto-adjust back up. That didn't happen. I haven't found anything on such a module. He said it woul be $109 for adjusting the lights OR for the module.
If I find anything more I'll let you know.
Apr 10, 2011 | 2006 Subaru B9 Tribeca
Can't adjust the height of the headlights
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Sep 13, 2009 | 2004 Audi TT
How do you adjust the headlights on a 2006 dodge ram 2500 ?
Jul 28, 2009 | Dodge Ram 2500 Cars & Trucks
Hi, could you please advice me how i can adjust the headlights for 92' toyota corolla? Thank you
Jul 10, 2009 | 1992 Toyota Corolla
How do you adjust the headlights in a 2005 Chevy Colorado?
Jun 15, 2009 | 2005 Chevrolet Colorado
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
CTX Optoma EzPro 610H Multimedia Projector Logo
90 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
