Question about RCA RS2041 CD Shelf System
Rca radio error code
I have an rca shelf radio at work and the cd player and auxillary are fine but when you swith it to tuner it comes on but there is no sound and it says open error code 255 or 2555
3 Suggested Answers
  • 39 Answers
SOURCE: open error 255
pls check supply voltage to tuner circuit,since this is digital tuner check digital clock and data.if you dont have scope to check,may be you try with vom meter and check about 4.7v on both line.when you select tuner notice slight flicker on your metre which will give hint of clock and data present.
Posted on Dec 17, 2007
  • 5 Answers
SOURCE: rca rs2663 shelf system
i think its a defect in the system
Posted on Aug 13, 2008
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
Where do i plug in the Aux cable
On the back of this system, do you see a group of RCA plug outlets? Marked IN and OUT? Phono IN? Phono OUT? Speaker IN? Speaker OUT? CD IN? CD OUT? Look for the one marked AUX IN or AUX OUT. AUX IN lets you connect a separate device, could be colored Blue, Green, White. Usually paired one over the other, RED over WHITE, YELLOW over WHITE, ect. If this system will accept an auxillary unit, player, ect, then it will have an AUX RCA type plug on the back.
Sep 26, 2009 | RCA RS2041 CD Shelf System
Tuner does not work
If you're trying to listen to FM, and are indoors, and your walls are fairly thick, or brick and mortar, chances are you're not getting a strong enough signal.
Modern minisystems like yours come without an external antenna, and use their power cords in lieu of one. Try extending the cord, not coiling it, for better reception.
Other than that, your system may have had a spontaneous problem to its FM tuning module, though not likely.
Aug 29, 2009 | RCA RS2664 Shelf System
CD ERR is displayed on my stereo
try using a cd cleaner first
May 30, 2009 | 2004 Honda Accord
Radio on my sony rx d7 hi fi 3 cd changer
check to maks sure you have an fm antenna connected
Dec 19, 2008 | Audio Players & Recorders
That is short for CD error. this means the CD player has some kind of problem
Oct 11, 2008 | 2004 Honda Accord
Can't get the auxillary to play or even come up
when its on standby hold the menu button and then use the right nob to change aux on then press menu again and src untill aux shows. hope this helps
May 29, 2008 | Kenwood KDC-MP235 CD Player
Open error 255
Dec 16, 2007 | RCA RS2664 Shelf System
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
RCA RS2041 CD Shelf System Logo
59 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
