Back to:
Tags:
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Makes 2 cups instead of 1 when you only want 1
posted by bauntorun on Apr 29, 2008
The machine makes 2 cups when you press just 1 cup. When you press a cup size (e.g. medium or big), as it starts grinding, it says "1 cup" as it should. However, a few seconds into the grinding, it automatically (by itself) turns to making "2 cups". This doesn't happen all the time, but enough to make it very annoying, not to mention wasteful. Thanks in advance for any help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 10, 2008
Not Rated (0)
mirran
Rank:Guru Guru
Rating: 88%, 213 votes
You have to change the touch card on the machine.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Makes 2 cups instead of 1 when you only want 1:
I don't want to Accept this solution
Can you Help with these Coffee and Espresso Makers problems?
How do you program a Black & Decker DCM 1350 coffee...
Hi guys am looking at buying an espresso maker for our...
Saeco 00034 Incanto Sirius Super Automatic...
I have an Incanto S-Class Sirius and when I try to use the...
who has saeco parts in stock in new york city? i need the...
The machine will produce steam for a short period of time...
Loading problems.
Repair Service
Find Coffee and Esp. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
