WE HAVE A XEROX DC3535 WHICH IS COMING UP WITH AN ERROR 116365
116-365
Posted on Apr 22, 2010
    President:
  • 2,072 Answers
Description Fatal error of the SPL
Due to an error during the software processing, the subsequent processes cannot be performed.
WE HAVE A XEROX DC3535 - arrwup.gifInitial Action Switch power off then on. If the problem persists, continue with the procedure.
arrwup.gif Procedure Perform GP 3. If the problem continues, reload system software. If the problem persists, replace the ESS PWB ( PL 13.1).
Posted on Apr 29, 2008
  • Rick Kasper Apr 30, 2008
    The code was able to be cleared utilizing "Log initialization" from the special boot codes menu located in GP3 of the Edoc. The log initialization is holding down the pwr sav, stop, and the "1" keys and turning on the 3535, after the second time the dots appear on the 3535 UI the keys can be released.
I having dc3535 coming error 116-361
Perform re-installation of the ESS software.If the problem continues, replace the ESS PWB
Feb 06, 2012 | Xerox DocuColor 3535 Copier
Hie,am looking for a xerox M24 transfer belt at a cheaper price.Can you please help.Peter
One of the best prices I have seen and they have the best aftermarket support for Xerox.
http://www.partsdrop.com/belt-64k91451-xerox-style-dc3535-p-1782.html
Good Luck with your Xerox and Thank You for using Fixya.
Jan 11, 2011 | Xerox WorkCentre M-24 Color Copier
Dc3535 has an error code 102-319, 102-372 and machine also hangs after the code is displayed
u just try one thing
remove ur fiery power cable
and power on machine
if u make the xerox copies from the machine then issue with ur fiery software
or
if problem is same with this
then issue with ur ess software
i guess
Dec 19, 2010 | Xerox DocuColor 3535 Copier
Dc3535 does not start it keeps blinking at 1st spot
trying to
press Power saver + Cancel all + 6 at the time of power on
it clear all pending jobs
and then again try to power on
other wise it can be checked by PWS aoftware if you have
Oct 03, 2010 | Xerox DocuColor 3535 Copier
116-325 error code on docucolor 3535
Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
Sep 22, 2010 | Xerox DocuColor 3535 Copier
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser for another new one and still get it so suspect I need to do an NVM setting but don't know which? Can...
4-361 Drum Motor
Drum Motor failure.
Initial Actions
• Remove all Drum Cartridges.
• Perform REP 1.6.
Procedure
The machine is a DC3535.
Y N
Enter dC330 [004-003] and press Start. The Drum Motor energizes and the drives
rotate.
Y N
Go to Figure 1 of this procedure and measure voltage between the Drum Motor P/
J210-4 (+) and GND (-). +5 VDC is measured.
Y N
Go to Figure 3 of the +5 VDC Wirenets and troubleshoot the problem.
Replace Drum Motor (PL 1.1).
Dec 01, 2009 | Xerox DocuColor 3535 Copier
Xerox DC3535 Color Copier
No unfortunatly. That is done in the diagnostic mode on the 3535, and that is propritary sofware where the diagnostics has to be accessed with a laptop that has that software loaded onto it.
There are some resets you can do, but they wipe out all the NVM inforamtion. Once those numbers reach a certain level, they have to be reset via a laptop.
Now that being said, once it is accessed, the service rep CAN change that threshold to a much much higher number so you can run the parts to failure, which is more realistic.
Those parts are very easy to replace. And can be purchased from a business called The Parts Drop, Google that business and talk to Britt. No I do not work there, but have dealt with them for years and they are very professional and exceptionally honest.
Jul 08, 2008 | Xerox DocuColor 12 Color Copier
411 people viewed this question
jasbo
jasbo
