Question about ViewSonic OptiQuest Monitor
Screen goes blank after few seconds
Lcd comes on with a hum and goes blank after a few seconds
  • rdeno121212 May 01, 2008
    My screen goes black after a few seconds and will not come back on unless I turn it off. When I turn it back on it does the same thing. I can not get it to come on at all when I connect it to my laptop like I have been able to do with other monitors. I would appreciate any help with this problem.
  • paulnebusol Apr 30, 2009
    I have the same problem but it is not the board or the power supply as I ruled them out by attaching the monitor to anoth PC and laptop (not at the same time)
    This is definitely a monitor problem
    Problem Solver:
  • 8 Answers
Yeah, for most of you it's definitely the caps. The three that are 470uF and the one 330uF.
Don’t just replace them with new ones of the same type, they will just blow again. Use ones with a higher voltage rating. you can also use ones with slightly higher uF (they are just output caps for the SMPS). Mine are at like ~530uF and its holding strong.
If your having trouble with brightness there is a jumper that lets you change the amount of power going to the cold cathode bulbs. It is right next to the three bigger caps. it has three settings, 6.5mA, 7mA, and 7.5mA. it should be set to 6.5mA by default. The bigger numbers are brighter, but remember to crank your brightness all the way down before changing this jumper as 6.5mA with maxed out user brightness is the same thing as 7mA all the way down.
These are good monitors as far as stats and usability. They just have defective parts. I was amassed with how "defined" the picture is per-pixel considering it's VGA.
-Oblivion
Posted on May 06, 2009
Hi guys
if your diplay goes blank afeter few second most of the time th proplem is located in the power supply area.
I had the same issue on my monitor and I have fix it !
what I recommand you to do is :
on the power supply check the 470 mfd capacitors they are probably almost dead also the 330 mfd close to the little coil and the 10 mfd close of the heat sink
the cost of the repair is approx 5$
hint: when you replace the capacito try to buy 105 instead of 85 and if you have enough phisycal space take 50V instead of 25
this way the capacitors will last a little bit longer
Posted on Feb 01, 2009
My screen goes black after a few seconds and will not come back on unless I turn it off. When I turn it back on it does the same thing. I can not get it to come on at all.
Posted on Nov 14, 2008
  • 3 Answers
I have had this same issue with a few of the Optiquest Q7 monitors. These seem to be very crappy and I have seen nothing good written about this monitor. I have a few I use that have the flicker on the screen which I have only gotten two of them working.
If the Screen goes comes on and turns off, it means the Power Board on the inside is bad. By opening up the monitor and taking one of the monitors with a bad video card to I get these working agian. They work for while, but expect the same issue to eventually start up again. Also by opening up the monitor be careful to set the LCD screen on something soft, otherwise your fix will end up just becoming another issue with white or black blotches on the screen. The two computer repair companies I have seen for fixing this monitor say that is normal, but they just don't know what they are doing. I am curently using one of the two I have fixed.
Another issue I am having is the Back light is shutting off itself. This I have not found a fix for as I have just opened this one up today. I will be digging deeper into this one as I need to find a way to remove this light and use the other light from the bad LCD screen. It kinda does the same issue, but the light at the bottom does not go on and off stating that the power board is not working properly. U are able to see the screen very faintly from very weird angles.
My last issue is the Video Boards seem to go bad as well. This has a few different problems and think its related to what goes wrong on the video board. I have seen things to just part of the screen not working, lines down the middle of the screen, and flickering issues.
The best fix for any of these issues has been trial and error. The other Q7 monitors that have started to fail I just pull out the guts of the monitor and place them in others till I get one to work. Once you find one that works you can just set up the other boards and LCD screens to find out which pieces are bad and unusable.
Hopefully this helps. thought I would post my issues along with ways I have gotten them fixed. I am still looking for actual blueprint designs of these Optiquest Q7 monitors to keep them in the best shape possible to get as many as I can fixed. I have a few LCD screens that are bad so eventually I will just be tearing into them.
Posted on Jan 07, 2009
Mybe you but the brightness too low, try to turn the moniter on and press the botton next to the power botton on the right, and incres the brightness, do it fast, it will stay on
Posted on Dec 05, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Screeen comes on --then goes blank
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Apr 15, 2008 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Computers & Internet Logo
3,160 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
