Question about Gaggia Titanium Espresso Machine
Watery coffee just seems as if when process begins....a little coffee comes out followed by ALOT of water......making very gross/watery coffee! please help as wife is now on me for wasting money!!!!!!! thanks. derek brister
  • 833 Answers
Sounds like you're not packing the coffee tightly enough into the unit. You've got to tamp it quite tightly...that's why the pumps are so strong. Each 'atmosphere' is 15 pounds of pressure. My son also likes to make his by doing two double loads to get one espresso cup.
Posted on May 09, 2008
Watery espresso
Need to make a finer coffee grind, and use better quality espresso beans, the best comes from Italy, I like Miscela d Oro
Apr 08, 2014 | DeLonghi BCO120T Programmable Espresso /...
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
How do you clean the coffee maker? My wife put vingar in it to clean and ran it through the coffee making process. Now...after running several cups of water through it we still have a vingar taste. ...
Lol! Your wife did the correct thing. (Hate to say it)Vinegar is acidic and eats away at all of the impurities that tap water leaves behind. To clear the vinegar, follow these instructions to a tee. Run one shot glass of bleach...yes bleach...through the unit. Follow this by two or three cycles of plain water. Your coffee will taste better than ever! And get this, bleach kills 99.999 percent of all bacteria known to man! Look it up! Hope this helps!
Jan 07, 2011 | Keurig Elite B40 Coffee Maker
No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Aug 01, 2010 | Miele CVA615 Espresso Machine
No real water run through coffee part
Your problem can be cause if you are using more than 7-7.5 gr of coffee. The coffee might be very fine so you should use more gross grounded coffee. Or the vebration water pressure pum is not working or is making presuure less than 9 bars so it might need cleaning or replacing.
Good Luck
Please remeber to vote for this answer
Feb 27, 2010 | FrancisFrancis! X1 - Stainless Steel...
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
White smoke comes out tail pipe
Its perfectly normal.Hot exhaust gases mixing with cold air and by products of the combustion process create the watery substance that you see spit out .Dual fuel (LPG,Hydrogen etc) vehicles do this a lot more noticably.By products of the combustion process are various but water vapour is one of them.Alot of heat is generated by the exhaust so watching a car driving in very cold conditions you can see this effect more clearly
Oct 18, 2008 | 1984 Oldsmobile Delta 88
Espresso is dark and rich at first; then shifts to water
This is suppsed to happen, every espresso machine out there on the market does this.
All the taste for the coffe comes in the first couple of seconds and after that it gets less and less.
So the problem is not that it gets lighter and lighter, but that you dont get enough taste in the start of the brewing.
And this can be caused by alot of things.
Bad beans?
Not set the grinding to fine?
it will not heat enought and thereby not get enough taste.
etc.
Apr 12, 2008 | Saeco Talea Giro Espresso Machine
Water Too Hot, Coffee Too Watery
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
www.CeriniCoffee.com
Jan 01, 2008 | Saeco Classico Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
360 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
