Question about Microsoft Excel for PC
Matching data i have students' grades for BGCSE exam scores that i want to match to their JC scores in two different workbooks from excel
  • 35 Answers
1. Open up both workbooks.
2. Copy one worksheet from one workbook to another using.
Right click on the tab of one book and Select "Move or Copy"
3. A dialog box will appear..Next to the "To book" select the workbook you want to move it to.
4. Be sure to select the 'create a copy' box in the bottom left of the dialog box.
5. Sort each worksheet by students name. Data..Sort.
6. Copy the scores from one sheet to another.
7. You then you can manipulate the scores and compare anyway you like by using formulas in different columns.
Posted on Apr 30, 2008
How Repair of Excel file?
If there was such problem, the simplest decision is described here:
http://www.excel.repair/ - Excel Repair Kit. A Microsoft Excel repair tool for corrupted Excel spreadsheets. Program open, read and save data from damaged Excel files.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise:
1. Click the Microsoft Office Button Office button image, and then click Open.
2. In the Open dialog box, select the corrupted workbook that you want to open.
3. Click the arrow next to the Open button, and then click Open and Repair.
4. Do one of the following:
3. To recover as much of the workbook data as possible, click Repair.
(a) To recover as much of the workbook data as possible, click Repair.
(b) To extract values and formulas from the workbook when an attempt to repair the workbook is not successful, click Extract Data.
Oct 17, 2015 | Computers & Internet
A BATSman has a certain average for 17 innings he scores 96 runs in 17th match there by increasing his averade by 3 what was the average after 17th match
average after 17th match=48
average before the 17th match was 45
after scoring 96 runs in the 17th match his average increased by 3
hope you are satisfied
Mar 02, 2010 | Vivendi Excel@ Mathematics Study Skills...
Whenever I open a new spreadsheet now it automatically opens up a spreadsheet calles PERSONAL. Why is that and how can I get rid of it... I think it started after a did a macro but I am not sure. Thanks,...
You're right - it was caused by recording a macro. When you record a macro you are given the option to store the new macro in "This Workbook", a "New Workbook" (the default), or in a "Personal Macro Workbook". It looks like you selected "Personal Macro Workbook".
The recorded macro is stored in a special workbook called "Personal.xls". This workbook is loaded every time Excel is loaded. If you don't want this workbook loaded, then just delete it or rename it.
The file is buried deep in Microsoft's application data area. On my Vista computer it's in C:\Users\frogfund\AppData\Roaming\Microsoft\Excel\XLSTART On my Windows XP computer it's in C:\Documents and Settings\frogfund\Application Data\Microsoft\Excel\XLSTART. Depending on your computer your Personal.xls might be in a slightly different location. You might need to do a search using Windows Explorer.
If you are still having troubles finding personal.xls 1. Open Excel, 2. Open the Visual Basic editor (hit Alt-F11 or click Tools-Macro-Visual Basic Editor) 3. Click Tools-References to bring up the references dialog 4. Click on VBAProject in the list. The file location will be displayed near the bottom of the dialog box. Sometimes this might be cut off at the end, but it should give you a good idea where the file is located. 5. Click Cancel to close the dialog.
Sep 23, 2009 | Microsoft Office Excel 2003 for PC
What are uses of vlookup n hlookup?
An implementation of the vlookup in Excel could be:
You have an Excel table with student names and their grades.
You wish that you could somewhere in the sheet type a student name, and immediately retrieve his grade (based on the data in the table).
To achieve this, you can use "Vlookup": the function will look for the student’s name in the first column in the table, and will retrieve the information that is next to his name in the second column (which is his grade).
Hlookup is the same excpet it is for data arranged by rows instead of columns.
Dec 29, 2008 | Microsoft Office Home and Student 2007...
HOW CAN I MATCH THE TWO WORKSHEET FOR RECONCILIATION
Try this:
1. Find the copy of the workbook on which you will merge the changes. In Excel, go to "File > Open" and find the file.
3. Click "Tools > Compare" and "Merge Workbooks." 4. Look for the files you want to merge and add them into the current file. 5. Click “OK” to merge the files. This is your master copy of this workbook. 6. Save the file.
Dec 21, 2008 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Jul 12, 2008 | Excel (SS8SATAS5128400R)
MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Apr 29, 2008 | Microsoft Excel for PC
Merging Data in 2 Separate Excel Workbooks
If the First Name and Last name are equal to both work sheets, I will just sort them by First Name and Last name and copy the results into a separate work sheet. If the names are different you will have to use Access: This can be easily done with Access and SQL, just import both work books into different tables to access and use the create query wizard, play with the results until you will get the result you want. Access will also solve the duplicate problem easily. Very important: You will have to use join properties: Read help about join properties and understand how this works... Afterward you can export it back to Excel or use Copy/Paste. If you can't use Access and have only Excel: You will have to use Vlookup on various fields until you will get the result you want. Its a hard work but in the end you will get the same result as access. Let me know what happend Daniel
Aug 20, 2007 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
248 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
