Error 106 saving a visio file - Computers & Internet
I get error 114 when trying to open a Visio file with Visio 2000. The helpline number 0800 834859 is defunct.
Either upgrade to the latest version of Visio, or have whoever created the drawing resave the file in the Visio 5.0 format.
To save a Visio 2000 drawing in the Visio 5.0 format:
  1. Open the Visio 2000 drawing.
  2. On the File menu, click Save As.
  3. In the Save as Type box, click Visio 5 Drawing (*.vsd), and then click Save.
May 11, 2011 | Microsoft Visio 2000 Standard for PC
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
Error code 106, how to correct?
have you try to reinstall the software ??
You do it in this way, uninstall the software, reboot the computer and then reinstall the software.
If it still not work then return here :O)
have a nice day
please rate my answer
Oct 24, 2009 | Adobe Photoshop 6.0 for PC
I need 2007 visio product key
in that ms office setup product key file is their select wher u saved th ms office files to get the key easier
Apr 17, 2009 | Microsoft Office Standard for PC
Visio file association
- in windows explorer right click over the file and choose Open with... and then browse for and choose the viewer program
Apr 03, 2009 | Visio Technical 4.5 Full Version for PC
ERROR CODE 106
restore your system to previous date where its working fine then check
Nov 05, 2008 | Adobe Photoshop 7.0 for PC
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
1,110 people viewed this question
David Payne
David Payne
