Question about Thermador RDFS30 Dual Fuel (Electric and Gas) Kitchen Range
Drip pan I would like to replace my drip pan - has anyone ever done this and how hard it is to do.  Any suggestions?
  • Rubby Apr 29, 2008
    Thermador RDFS30 dual fuel
I don't have a solution, but I am trying to figure out how to remove the sealed burner drip pans on a Thermador PRSG 364 GLS gas stove. Any suggestions?
Posted on Nov 17, 2008
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
Need replacement drip pan for model #GRP4P Part # 22619
my proublem is solved. I was looking for a replacement "Drip Pan" for my George Foremen "The next grilleration" grill. The solution is, I googled it. (George Foremenr replacement parts) It sent me to their sight and as you sroll down the page to the bottom you will see comments from other people who were also searching. And some from other who have found answers. You will see a toll free number where you can order your replacement parts for several appliances. My replacement "Drip Pan is on the way.
Apr 12, 2009 | George Foreman GRP4P Indoor Grill
OIL DRIPPED OUTT!!
The oil pan was broken. They are made out of aluminum or cast iron. but i think it's hard aluminum. You are going to have it replace it. Don't drive the car without oil.Anyone can do it . Lift the car and secure it so it won't fall. Then remove that plastic thing you mentioned and remove the bolts around the pan . It has several . Be sure to buy a pan and gasket along with the pan.And replace.
Jan 11, 2009 | 2000 Volkswagen Golf
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Jan 03, 2008 | GALAXY Microsystems 63702 Top Freezer...
Thermador RDFS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
472 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
