Have a Toshiba DLP model 62JM9UA and my son has touched one of the touch controls on the front.It seems that the tv has gone into lock mode.Green light flashes twice followed with a pause.Any help would be greatly appreciated as we have moved house and have misplaced the manual.
Replaced the blown lamp
Posted on Apr 30, 2008
Toshiba touch tv not responding to remote control or touch sensors
Do a hard reset, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 13, 2016 | Toshiba Televison & Video
Toshiba Gigabeat Touch Controls broken - need to transfer music to iPod
remove front cover on Gigabeat F40, remove battery. on back of battery a spacers remove those and replace with thinner spacers. I used hi quality insulation tape three layers of and stick back onto battery. Install battery again and it will have fixed the problem. Did it with mine
Jun 15, 2012 | Toshiba Gigabeat F40 40 GB MP3 Player
I have replace the bulb in my 62" Toshiba 62JM9UA and my tv still wont give me any picture or sound. What is wrong with it?
Hi I've also had this problem and it was the balast! Don't ask me what the hell it is the tech bloke replaced it and bingo it worked. Hope this helps
Jul 27, 2011 | Toshiba 62HM95 62" DLP HDTV
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
My sons ipod touch's screen has gone white and won't reset. Turns on and off and can be connected to computer but the screen remains white
Have you tried this?
Hold the home and lock buttons for about 10 seconds until the Apple icon appears on the screen. This is called a "Hard Reset."
If that doesn't work, try this next step, but be aware that you will be required to restore the iPod, meaning deleting all songs, videos, or any other data on the iPod, make sure the items are backed up before hand.
Hold the home button (on the front) while plugging it in to the computer, continue to hold the button until it becomes responsive.
iTunes should say it has been recognized in restore mode, and you can restore by clicking "Restore" from within the iPod touch via iTunes.
The best of luck to you, hope these could help!
Sep 19, 2010 | Apple iPod touch
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
My color is washed out and dim and the colors are wrong . Toshiba 65h83 projection hd tv
I don't know your model, therefore I will tell you genericaly what the problem may be.
There are many things that can cause this type of fault. The response of the video amplifier stages would have to be checked right up through to the output that drives the projection. it is also possible that there is a fault with the colour demodulator. If the set uses projection tubes it is possible that the tubes are weak, or there is dirt in the optics. Colour demodulation problems can also cause the colours to not be correct. Many models using tubes have an optical transparent cooling fluid in front of the tubes. This fluid may have to be changed.
Feb 23, 2009 | Toshiba 42H81 42" Rear Projection...
Still green
go In service convergence mode and try to adjust red and green if you cant then it's convergance amp ic's
if you can adjust them so they align up try doing a touch fous after that,.
Dec 16, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
