Question about Nokia 6600
Problem with my nokia 6600
I have a problem with my nokia 6600, I cannot open the gallery as well as the bluetooth.my file explore, internet services will not also open. my phone in general is very slow and i have reseted and flashed it almost everyday but will not work normal.please help!!?
  • creative_257 Apr 13, 2009
    bloothut and gallery is not open after flashing kindly solve my problem ok
    Problem Solver:
  • 3 Answers
Posted on Apr 14, 2009
    President:
  • 1,257 Answers
Try fomatting or flashing your mobile ,and definitely it will solve all your problems
RESETTING PHONE BY NOKIA SECRET CODES (steps 1 and 2)
1st step : SOFT RESETTING NOKIA MOBILE
Take backups of ur phone books,calender and others, then simply enter the code
*#7780#
2nd step : HARD RESETTING BY CODE
Just enter the code-
*#7370#
Then it asks for security code enter ur security code whose deafault value is 12345
NOTE:
The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
FLASHING
3rd step :FLASHING : ANOTHER METHOD FOR HARD FULL FORMATTING
This step is known as flashing of phone. Always do this step at last (after 1st 2 steps are over and u are not successfull)
1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be left)
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your mobile phone.
4. Press and hold these three keys together
-Green dial key,-Star key (*)-Three key (3)
then press the power on/off to swtich on the phone.
Do not let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your mobile will now be at its original factory settings (It will reach the same state as that in when you purchased it).
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Posted on Apr 30, 2008
    Novelist:
  • 124 Answers
Hello!!!
for solution of ur nokia 6600 problem, i think u should format ur phone memory as well as memory card at same time (turn by turn). reset the phone memory by *#7370# or *#7780#. if this doesnt work, u should update ur software versions.
Posted on Apr 29, 2008
Nokia 6600: Bluetooth wont open
solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
Mar 17, 2011 | Nokia 6600
Problem in opening gallery
you should try to reset/format your phone,
sometimes we install some applications in phone, it makes unnecessary library files,
it causes problem in normal functions of the cellphone, like Camera not work and stuff like that.
so you should try!
May 11, 2009 | Nokia 6600
Nokia 6600 problem
to guest, n6600 by default can't recognize mp3 file, even if you have installed mp3 player on it you can't still open it via bluetooth, what you have to do is copy the file on your mmc, from there your mp3 player will detect it, download ultra mp3, wmaplus, lcg jukebox,
Sep 10, 2008 | Nokia 6600
Nokia 6600 Bluetooth, gallery problem.
yez.,, its a hardware problem, you just have to replace the bluetooth module of your phone, or go to a near repair cellshop and ask them to do that,, when you open gallery it only stuck up on opening and when u use your camera, it says temporary overload ryt?? and some application won't work, the only thing is to replace the bluetooth module of your phone
Aug 24, 2008 | Nokia 6600
Bluetooth
hi there,
Please go to your nearest repair shop. Ask them to fix your Bluetooth Chipset. Its damaged and need to be replace.
The damaged blutooth IC affect file manager and gallery.
br
Aug 07, 2008 | Nokia 6600
Nokia 6600 prob
my phone do not shows network actually but sometimes it shows full and goes on decresing and be nil
Jun 08, 2008 | Nokia 6600
Nokia 6600 gallery is not opening
Toujours Msgs envoyés
May 27, 2008 | Nokia 6600
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow.
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
Dec 07, 2007 | Nokia 6600
Cannot open gallery
try to reformat ur fone!!
Sep 25, 2007 | Nokia 6600
Bluetooth and gallery
i use that phone but never being like that.i think you should check all setting back
Jul 01, 2007 | Nokia 6600
Nokia 6600 Logo
137 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
