Convergence ics i have a phillips 60pp9202 60 inch rear projection television and i have a red rainbow at the bottom of the screen and i also have seperation of the red whenever there is writing on the television. i was told this was a convergence problem and that replacement of the ics would solve this problem. on your post it said you could tell me where to buy the replacement ics along with step by step directions to do this. please send me the link to tmuns715@charter.net if this sounds like replacement of the ics will repair my problem. thank you for any help you might be able to give me.
  • 8,617 Answers
Heres the link and yes they do provide the step by step instructions. You need to replace both ICs part number STK392-120 heres the link
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
I have my panasonic tv
This is a convergence problem and is either bad connections at the convergence IC or defective ICs. If you can solder, try resoldering the pins on teh convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large black ICs attached to a heatsink and may be marked STKxxx.
Keep us posted on your progress.
Dan
Jun 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rear projection
check or replace convergence ic exact duplicate
May 27, 2008 | Philips 50PP9202 50" Rear Projection...
Red will not converge even after I replaced both IC's. Please Help ASAP!
I have a phillips in my office like this. There are a few things to check. Check the resistors around the red convergence ics it is probably open resistor or resistor fuse take your time and check all the resistors.In rear cases it could be the surface mount ics on bottom of convergence board i hope that is not the case.
thanks doctor video leading edge electronics
May 08, 2008 | Philips 43P8341 43" Rear Projection...
50P8341 red bows
Convergence ICs or the resistors powering them are bad. Check for open resistors near the ICs if any are open, change both ICs and the resistors.
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
51mp392h/17
HAVE RED BOW . BLUE IS GOOD . RED I CANT AJUST JOESTV2003@YAHOO.COM
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
