posted by stoplooking on Apr 29, 2008
took door off my jen air oven to move and can't figure out how to put it back on. please?
Solution #1
posted on Jun 19, 2008
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jenn-Air JGS8750 Gas Kitchen Range
Email this problem
Email this problem
Can you Help with these Kitchen Ranges problems?
jenn air natural gas range
other burners make a clicking... Answer This...
jenn-air glass cooktop 36"
one burner is not working -... Answer This...
Jenn Air convect all gas stove
When the oven is on, it keeps... Answer This...
Jenn-Air gas range F9 indicator
What is it and how do I get it... Answer This...
front panel is hot!
front panel is hot!
Oven was showing F1-8 error.... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
Find Parts
